Question for the boosted LS
Old Apr 9, 2003 | 08:03 PM
TSIntegra's Avatar
Default Question for the boosted LS
I have stock injector right now and i want to know what is safe fuel pressure before they burn out is 7 pounds ok with stock injectors, i have the rest of the fuel system, pump, rail fuel regulater? Tell me what you think or have done(and it worked)
Old Apr 9, 2003 | 08:54 PM
romeo619romeo's Avatar
Default Re: Question for the boosted LS (TSIntegra)
umm you dont have the boost dependant FPR? the small little one isnt gonna do much you will be runing lean with that
Old Apr 9, 2003 | 10:00 PM
X2BOARD's Avatar
Didn't quite understand your setup... What do you have past the stock injectors as your fuel ?
Do you at least have a POS FMU ? If you are just running a stock fuel system (stock injectors, FPR, pump..etc...) After 3-4psi you will run dangerously lean.
X2
Old Apr 9, 2003 | 11:14 PM
SIK IN DA HED's Avatar
New User
Default Re: (X2BOARD)
stock injectors should be able to handle 7psi. it isnt unusual to find guys runnin 9psi with stock injectors. of course.. with an inline fuel pump and fmu at least.
thanh4o8
Feb 6, 2009 10:53 AM
ej8
Jul 30, 2007 03:20 AM
AZNracerx1989
May 17, 2005 09:14 PM
Tex Blackwell
May 6, 2004 03:45 AM
pelotudo
Sep 14, 2002 12:35 PM
