Tech help!!
Old Apr 9, 2003 | 06:21 PM
ILLA_00LS's Avatar
Default Tech help!!
need to know a few things here, my friends and I are trying to work the bugs out of the EMS system. need to get the car up and running soon!! so here is what i'm looking forb18b)
Teeth on crank
Firing order
last one... need to know when WHAT injector fires on WHAT tooth of the crank(ie. injector 1 on tooth 5,injector 2 on tooth 12, and so on)
please help me out or send me some web sites that might help me out! this will mean the world to me if yall can give up this info!!
thanks yall!!
Old Apr 9, 2003 | 06:46 PM
Neukin's Avatar
Default Re: Tech help!! (ILLA_00LS)
is this the aem ems?
Old Apr 9, 2003 | 06:58 PM
Quik Chris's Avatar
Edit: Oops, thought you were talking about plugs, not injectors Sorry
Old Apr 9, 2003 | 08:38 PM
psi420's Avatar
Default Re: Tech help!! (Quik Chris)
Dont they have base programs already with that information?
Old Apr 10, 2003 | 02:56 AM
ILLA_00LS's Avatar
Default Re: Tech help!! (psi420)
yes it si for the AEM EMS, and YES they do have base maps, but looking at all of the maps we have picked one for a CIVIC w/ a type R w/ t3/t4b,JE 9.2:1 pistons, stock rods(don't ask why, i thought most people would build the motor if the craked it open) and 440's. but looking at this map, they had injectors 1,2,3 and 5, ON?!?! they compleatly skipped the 4th injector, also had some other **** on to.. i'm just trying to get this up and running with all the right info! PS
if anybody is running the EMS system on there TURBO LS w/ 440's, and they got a GOOD map let me know!!
Old Apr 10, 2003 | 04:44 AM
Neukin's Avatar
i have the aem ems too. all you have to do is load up a map for a car that uses your engine and is the same obd. then open up the fuel chart in the turbo one you liked and copy the fuel settings then open up the calibration that has the same obd and engine and paste it in that ones fuel chart.
have you used the ems before.
go to ecu connect with the key almost turned on all the way(so you hear the fuel pump)
to to file open (open the map you want)
then go to ecu upload to get that one that you opened onto the ecu
then next time you go to ecu connect that one will pop up and you can edit the fuel map
Old Apr 10, 2003 | 06:38 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ILLA_00LS &raquo;</TD></TR><TR><TD CLASS="quote">need to know a few things here, my friends and I are trying to work the bugs out of the EMS system. need to get the car up and running soon!! so here is what i'm looking forb18b)
Teeth on crank
Firing order
thanks yall!!</TD></TR></TABLE>
there are two triggers, a specific trigger in the stock distributor has 4 pickups on the rotor shaft buried inside the distributor casing ... that fires your injectors in the order you put into the EMS, i.e. 1-3-4-2
greg
Old Apr 10, 2003 | 08:51 AM
dfoxengr's Avatar
Default Re: Tech help!! (CHEETAH)
talk to the techs on the AEM board....theyre smart..
Old Apr 10, 2003 | 12:17 PM
ILLA_00LS's Avatar
Default Re: Tech help!! (hybridvteceg)
thanks for the tips and help... this is my first time w/ the EMS system, BUT i do know how to use a PC so geting everthing uploaded is all good done that.. the car runs.. like ****.. VERY VERY RICH.. and idels hard! i have posted on EMS forum with no luck so i came here.. hopeing to find my answers..
still wating on the the other 2 qestions i had.. thanks yall..
Joeynapp
Jun 26, 2011 03:51 AM
Gkdc182
Mar 20, 2010 06:38 AM
slowwhitehatch
Engine Management and Tuning
Mar 23, 2009 04:28 PM
a1320honda
Dec 21, 2006 12:19 PM
eg2turbo
Feb 22, 2003 10:49 AM
