99-00 si rotors on a 93 civic dx...
Old Apr 9, 2003 | 05:21 PM
compwc18's Avatar
Default 99-00 si rotors on a 93 civic dx...
Would the rotors for a 99-00 Civic Si fit on a 93 Honda Civic DX Coupe?? Please let me know, thank you.
Old Apr 9, 2003 | 05:27 PM
EL Vap133's Avatar
Default Re: 99-00 si rotors on a 93 civic dx... (compwc18)
I believe the rotors on the DX are smaller....
Old Apr 9, 2003 | 06:25 PM
kommon_sense's Avatar
Default Re: 99-00 si rotors on a 93 civic dx... (Vap133)
no they won't fit. si/ex/gsr rotors are bigger than other civ models.
Old Apr 10, 2003 | 06:35 PM
compwc18's Avatar
Default Re: 99-00 si rotors on a 93 civic dx... (kommon_sense)
I might be swapping a D16Z6 into my car. Full changeover. So then if I picked up some Brembo Cross Drilled Rotors for a 99-00 Civic Si, would they fit on the 92-95 EX Axels? or no??? Please let me know... Thank you.
Old Apr 10, 2003 | 06:39 PM
Built to Spill's Avatar
el diablo
yeah that should work. As long as you get the ex axles n stuff.
________
MERCEDES-BENZ C216 HISTORY
Old Apr 10, 2003 | 07:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by compwc18 &raquo;</TD></TR><TR><TD CLASS="quote">I might be swapping a D16Z6 into my car. Full changeover. So then if I picked up some Brembo Cross Drilled Rotors for a 99-00 Civic Si, would they fit on the 92-95 EX Axels? or no??? Please let me know... Thank you.</TD></TR></TABLE>
Nope... The axles aren't the problem. It is the front knuckle. If you swap the knuckle/spindle/hub/caliper then you can use the 99-00/92-00EX front rotors.
Also, save your money and get some brembo blanks.
Modified by kommon_sense at 12:26 AM 4/11/2003
fracas
Sep 29, 2005 02:54 PM
Superhatch
Apr 27, 2005 06:01 PM
igone916
Jul 14, 2004 07:32 PM
