Bed squeaking noise from front passenger side
Whenever I apply the brakes, the front passenger side makes a squeaking noise. It sounds someone getting it on on a busted mattress. I imagine a busted shock would make the same noise, but its only when putting on the brakes. Warped rotor? Or busted shock squeak from brake dive?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ReckedAccord »</TD></TR><TR><TD CLASS="quote">... Or busted shock squeak from brake dive? </TD></TR></TABLE>
Could be that, but you'd also hear it when the suspension flexes over bumps. Are your brake pads worn out? Could be the warning tab rubbing on the rotor?
