B17 cranks but wont start
Old Apr 9, 2003 | 04:27 PM
Hondasaurs's Avatar
Default B17 cranks but wont start
I recentley swapped a B17A1 into my 1990 hatch. It ran fine for 2 days. Now it cranks over but will not start. It is getting fuel and spark. Any ideas?
I converted the harness to OBD1.
Old Apr 9, 2003 | 04:44 PM
dfoxengr's Avatar
Default Re: B17 cranks but wont start (ZC_CRX)
try cam timing...and PROPER fuel pressure
Old Apr 9, 2003 | 04:46 PM
Hondasaurs's Avatar
Default Re: B17 cranks but wont start (hybridvteceg)
I had 2 fuel injectors firing in the wrong order because of the wiring diagram I was given. I corrected the problem not it just won't start.
Old Apr 9, 2003 | 04:50 PM
Kataku2K3's Avatar
Do you have a spark??? I assume that you rewired from DPI to MPI... Did you wire up the CYP, etc.??
dfoxengr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ZC_CRX &raquo;</TD></TR><TR><TD CLASS="quote">I had 2 fuel injectors firing in the wrong order because of the wiring diagram I was given. I corrected the problem not it just won't start.</TD></TR></TABLE>
u mean now?
try timing
Old Apr 9, 2003 | 04:54 PM
Hondasaurs's Avatar
Default Re: B17 cranks but wont start (Kataku2K3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kataku2K3 &raquo;</TD></TR><TR><TD CLASS="quote">Do you have a spark??? I assume that you rewired from DPI to MPI... Did you wire up the CYP, etc.?? </TD></TR></TABLE>
Yes I have a spark. I wired the fuel injectors directly to the pins on the ECU. I also did the same for the distributer. It ran fine but I got really bad gas milage and some back fireing through the intake. This is when I realized the injectors were on the wrong pins. I repalced the cap and rotor too. The spark plugs are soaked in gas when I pull them out.
Old Apr 9, 2003 | 04:59 PM
dfoxengr's Avatar
i had a very similar problem, CHECK ur damn cam timing...
Kataku2K3's Avatar
My bad, I didn't even originally see that you said you had a spark... Did you flip the positive and negative on your TPS... If you didn't remember that DPI is wired backward... 4.5-5.0vdc with the throttle plate closed and ~0.50vdc at WOT... What is your ignition timing at??? I would also check the MAP sensor... Is your vacuum line connected or if you have a throttle body mounted MAP is the port clear... Good Luck
Old Apr 9, 2003 | 05:01 PM
Hondasaurs's Avatar
Will do! Thanks for the advice. I hope I can get this thing going.
Old Apr 9, 2003 | 05:04 PM
Hondasaurs's Avatar
Another quick ? Are the yellow/black fuel injector wires grouns on the OBD1 harness?
Old Apr 9, 2003 | 05:05 PM
dfoxengr's Avatar
oo...i cant remember sorry..i dont think so...theyre power i think, but dont quote me...
Old Apr 9, 2003 | 05:16 PM
Kataku2K3's Avatar
#1 = brown, #2 = red, #3 = blue, and #4 = yellow... The yel/blk ones all trace back to the junction connector which applies 12vdc with the ignition on ACC... It also power up a few other sensors... IAC, oxygen sensor heating elements, etc. It's input from an OBD1 ECU is A25... Good Luck
MAFDARK
Dec 1, 2007 01:15 PM
love_5gen
11
Feb 25, 2007 11:22 PM
JDM_rolex
Aug 14, 2006 09:30 AM
SpoolinEK
Dec 10, 2003 02:28 PM
JBG's Ferio
Jul 31, 2003 09:14 AM
