ctr pistons
Old Apr 9, 2003 | 04:25 PM
juicedricer's Avatar
Default ctr pistons
will CTR pistons work in a ls block well???? no ls vtec here just strait raw ls.
Old Apr 9, 2003 | 04:32 PM
lazy bum shaughn's Avatar
Default Re: ctr pistons (juicedricer)
I think you have to do some custom stuff to your rods. I think.
duRritztiNy's Avatar
Default Re: ctr pistons (lazy bum shaughn)
you u can use ls rods
Old Apr 9, 2003 | 04:36 PM
Default Re: ctr pistons (SouthSideRacing)
so it will work and produce power???what would the compression go up to if thats done a freind of mine said it should probably work fine, he has them ina gsr and he said it moved his up about a point in compression. i am looking for good economy idea ways to make power.
Old Apr 9, 2003 | 04:38 PM
Chris y0!'s Avatar
it will bring your compression up to 11.4:1, stock is 9.2:1
with that compression, you should be making b16 power, with a lot more torque. you will have to run premium though.
Modified by Spoon Hybrid at 4:54 PM 4/11/2003
Old Apr 9, 2003 | 04:56 PM
13HYBRID20's Avatar
Default Re: ctr pistons (Spoon Hybrid)
11.71 to 1 if you use a mugen head gasket it will be 12.0 to 1
Old Apr 9, 2003 | 04:57 PM
Chris y0!'s Avatar
Default Re: ctr pistons (13HYBRID20)
no, its 11.4
where did you get 11.7 from?
Old Apr 9, 2003 | 04:58 PM
13HYBRID20's Avatar
http://www.c-speedracing.com/h...c.php
Old Apr 9, 2003 | 05:08 PM
13HYBRID20's Avatar
i'm wrong 11.4 is right but you can get 11.7 with a 2 layer head gasket
Old Apr 9, 2003 | 06:18 PM
mrctr's Avatar
I got ctr pistons in my ls block....we shaved 1mm off the bottom of the rod... it works....i'll post my et times with my block after may or june
Old Apr 10, 2003 | 10:45 PM
Default Re: ctr pistons (mrctr)
nice i will now get those CTR pistons and do some work to the non vtec beast!!!!thanks guys
Old Apr 11, 2003 | 01:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrctr &raquo;</TD></TR><TR><TD CLASS="quote">I got ctr pistons in my ls block....we shaved 1mm off the bottom of the rod... it works....i'll post my et times with my block after may or june </TD></TR></TABLE>
how does ur car run any negative effects from doing the CTR pistons???? i drive this car daily so driveability is important. this will be for basically a stock block with i/h/e/clutch and stock valvetrain. i just want to make sure it will make enough considerable gains for the price(get dealer price for honda oem parts )
cisurfer1
Feb 20, 2006 08:31 PM
mR. Vash
Jul 10, 2004 07:07 AM
JDMBB2
Feb 26, 2004 07:09 AM
ID_ten_T
Jun 15, 2003 04:14 PM
CanadaCivic
Nov 15, 2002 01:46 PM
