OIl pressure
Old Jun 23, 2001 | 07:28 PM
john94si's Avatar
New User
Default OIl pressure
OK on a Honda cbr F3 600, how can i measure if i have oil pressure? What can i measure it with, can i borrow one from an autoparts store? ----Reason my oil light came on, and i checked oil level good , frove another 1/2 mile and temp began to rise very quickly , i shut it off before it got to RED .. where do i start on diagnosing my problem??? I recently changed the oil <correct Honda OEM filter and oil> ??
Old Jun 23, 2001 | 08:00 PM
01PYtr1092's Avatar
New User
Default Re: OIl pressure (john94si)
John,
Since you recently changed the oil filter, there may be a filter clog or stopage that is reducing the oil pressure. I also recomend you go back to the Honda place that sold you the oil and filter and ask them about your problem.
Good luck.
[Modified by 01PYtr1092, 9:05 PM 6/23/2001]
Old Jun 27, 2001 | 08:07 AM
figment's Avatar
New User
Find the oil pressure switch which is used to operate the idiot light. You will need to remove the switch find a tap and connect the oil pressure gauge to that hole. You can then measure the pressure.
MGF 1996 Accord
Jul 6, 2015 11:36 AM
eric416
Oct 9, 2008 04:03 PM
aznd87
Nov 6, 2006 01:32 PM
hondapwr
Mar 11, 2004 02:43 PM
boostlee
Dec 8, 2003 11:33 PM
