h22a in 98 integra
94-01 Integra engine chassis is the same as the 92-95 EG Civic. Thus, doing the swap procedure is the same as doing the H22 swap into any 92-95 Civic. Only main difference will be the wiring since your car is OBD-2, depending on what year motor you get.
i dont get this part hasport says
"The mounting bracket on the right-hand framerail will need to be removed or it will interfere with the shifter assembly."
what????i thought you just had to trim the passenger side upper mount
some one explain
some one explain
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yaya »</TD></TR><TR><TD CLASS="quote">
Meaning, with the HASport H22 mount kit, you need to completely hack off the passenger side bracket that's welded to the frame and bolt their parts from underneath. Only with the HCP EG-22 mount kit do you still use that frame bracket, and only trim off a small part of the rear arm only to clear the shifter assembly box.
ohhh NICE pic, now i see how the new mount fits....
i thought with the newer hasport kit you didnt need to chop anything off....now i see you do
cool thanks for that pic
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CvexH22 »</TD></TR><TR><TD CLASS="quote">
Just drill where it was spot welded on
or you could use the HCP and do this
I drilled where it was spot welded on, with the exact bit that Hasport says to, and I can't get the dang thing to come off....I've drilled out all the spot welds, accidently went through to the frame rail in one spot, and the dang thing will still not come off. Even with a 15lb sledgehammer it just shakes the whole car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yayaRl337 »</TD></TR><TR><TD CLASS="quote">hey for the HCP you just redrill the smaller hole on that bracked right?</TD></TR></TABLE>
Yes you need to drill the hole out using the little pilot hole that is already there. If I remember correctly you need to use a 9/16 drill bit for that hole!
Rybear
Mar 2, 2015 02:11 AM
SOJAMR1
May 12, 2005 07:13 AM
