just INSTALLED vafc
just finished installing my vafc. now my check engine light is on and is blinking. "slow slow fast slow slow fast fast" thats code 43 correct? code 43 says "Fuel Supply System defective or malfunctioning fuel supply system". can anyone help me out by telling me what i would need to do to fix that? i have no clue.have any of you guys encountered this problem? also do i need to hook up the blue VTM wire. i have a 93 dx with 00' b16a2.
btw. i feel free to move this post . but i think it should stay.
hook up the vtm wire and if its slow slow fast...thats twenty one...then slow slow fast fast thats twenty two..check those up i dont remember off the top of my head. it might be a soldering problem. check all your connections.
well now the check engine light is not on when i turn the car on but if i plug in the clip to check for engine codes it still throws the same code. but when i take it off theres no check engine light on my cluster.can anyone help me out? thanks.
also i took it for a spin around the block and stepped on it..and drove around for a little bit. but still got no check engine light on my cluster..it only comes on when i connect the clip down by the ecu to throw codes. my question is do i have to worry about it?
Modified by EGsixer at 10:50 PM 4/9/2003
If you car doesn't go into "safe mode" meaning you have all the power that you had before and you no longer have the check engine light on, I wouldn't sweat it.
Scott
Scott
Reset your ECU and then see if it still throws codes. Disconnect your -ve battery terminal for about 30secs should reset it or you can pull the "backup" fuse in the fuse box in the engine bay.
i will try reseting it and let u know what it does.
