Fuel Pump and ECU
Old Apr 9, 2003 | 12:42 PM
b16a1sirhb's Avatar
Default Fuel Pump and ECU
Will your ecu turn on if you have a bad fuel pump?
Old Apr 9, 2003 | 12:50 PM
chad174's Avatar
Default Re: Fuel Pump and ECU (b16a1sirhb)
yes, but i suspect the problem you are having is the same problem a couple of us have had without finding problems to it. you did a swap, and when you turn the ignition, your fuel pump nor your ecu turn on, right? good luck with it. ifinally wired a 12v switch directly to a13 on my ecu and to the yellow wire on my fuel pump and now i turn them on manually.
Old Apr 9, 2003 | 11:50 PM
b16a1sirhb's Avatar
Default Re: Fuel Pump and ECU (chad174)
I've already the problem with the ecu turning on before, it turned out that it was the two ecu ground wires went bad for no reason. So I just regrounded them. I know my fuel pump won't turn on if the ecu doesn't, but I was just checking if it was the same way visa versa. I know that my main relay is good, because I've already replaced that when I had the last problem. Anyway Thanks Again.
averyvm
Engine Management and Tuning
17
Aug 2, 2013 05:40 AM
Galan
May 21, 2011 03:55 AM
no_rice_please
Oct 12, 2009 09:36 PM
krysted9354
20
Apr 8, 2009 03:32 PM
bc matt
Apr 2, 2005 01:17 PM
