whats the best tranny for a b20/vtec swap
Old Apr 9, 2003 | 12:38 PM
cornholioEK's Avatar
Default whats the best tranny for a b20/vtec swap
whats the best tranny for a b20/vtec swap? is a 2001 Si tranny good for that motor?
Old Apr 9, 2003 | 01:36 PM
Newman's Avatar
New User
Default Re: whats the best tranny for a b20/vtec swap (DOHCvtecCR-X)
Any GSR/SiR/Type R transmission would be the best ideal transmission to use because of the gearing. Otherwise, any B-series transmission will bolt on and work.
Old Apr 9, 2003 | 11:32 PM
BoM's Avatar
BoM
Default Re: whats the best tranny for a b20/vtec swap (Newman)
depends if your built bottom to handle the revs.
depends on your revlimit.
depends on how you want to daily drive...
cause you can have 60mph @ 3500+/-rpms cruising
but the shortest will give you a faster time as traction permits.
Old Apr 10, 2003 | 04:20 AM
crxman00's Avatar
Default Re: whats the best tranny for a b20/vtec swap (BoM)
I'm running a 92 GSR Tranny on my B20 Vtec. @ 80mph I'm right at 4900 rpm. I haven't had a problem after 6000 miles and clockin'. If you are use to your B16a tranny you'll be fine. Expect the same...
Old Apr 10, 2003 | 08:36 AM
ITRacer121's Avatar
I am going to be running a Si with LSD once I get my block! I hope it should have around the same gearing as my R
Old Apr 15, 2003 | 12:26 AM
eg686's Avatar
Default Re: (ITRacer121)
is it true that b20 cant take high reving?
Old Apr 15, 2003 | 12:41 AM
irev210's Avatar
Default Re: (nocaryet)
i rev my stock bottom crvtec to 8200
so far, 5500 miles on the swap.
Ya wanna race
Mar 9, 2005 05:04 PM
eathatch94
37
Jul 7, 2004 11:08 PM
SpoonfedDC2
Feb 25, 2003 06:48 AM
kmf0211
Jul 16, 2002 11:06 AM
