Skunk2 IM Install NON VTEC
Old Apr 9, 2003 | 10:35 AM
J337_UNIT's Avatar
Default Skunk2 IM Install NON VTEC
Im going to install my Skunk2 IM soon on my 98 Integra GS, has anyone installed this item on a NON VTEC integra, If so, please tell me what items i will need to complete the install, and what kind of gains did you see. What size is the opening ? 64mm? because i plan on getting a matching T/B and a type-r aem intake.
Old Apr 9, 2003 | 11:01 AM
J337_UNIT's Avatar
Default Re: Skunk2 IM Install NON VTEC (J337_UNIT)
i tried searching, if your wondering and every time i searched it only came up with the install info for a GSR.
Old Apr 9, 2003 | 11:55 AM
JeremyL's Avatar
look forward to losing some serious low end torque if this is an otherwise stock motor
what are your plans for this motor? if ur not going boosted or serious na power imo its not the best upgrade for the LS motor
Old Apr 9, 2003 | 12:14 PM
FrostyDC4's Avatar
"Haters Gonna Hate"
25 Year Member
Default Re: Skunk2 IM Install NON VTEC (JeremyL)
I wish I could tell you what I needed to install it (I had a shop do it for me). I have the S2 im with a portmatched tb and ITR cai and I noticed great gains on the top of the powerband (most notably after 5.5k). You lose a little midrange though. The mani keeps the power (highrpm torque) from dropping at the topend of the powerband. Its a good buy if your car sees redline a lot.
Old Apr 9, 2003 | 05:26 PM
J337_UNIT's Avatar
Default Re: Skunk2 IM Install NON VTEC (FrostyDC4)
i plan on running a 35 shot with this set-up, but what hardware will i need.
Old Apr 9, 2003 | 06:03 PM
DK4200's Avatar
you will notice more of a gain from the aem intake. not worth it unless you plan on getiing agressive cams. save your money and mod something else
Old Apr 9, 2003 | 07:59 PM
J337_UNIT's Avatar
Default Re: Skunk2 IM Install NON VTEC (DK4200)
i do plan on getting crower stage 2 cams, valve springs, retainers and cam gears, prior to the 35 shot.
Old Apr 9, 2003 | 08:08 PM
J337_UNIT's Avatar
actually after researching alittle im going to go with the crower stage 1 cams for the b18b, its good for nitrous, and naturally aspirated it has seen gains up to 12hp when properly adjusted with gears. I think they would help me out with the lack of midrange power loss from the intake manifold. But what hardware will i need?!? anyone?
Old Apr 9, 2003 | 08:14 PM
kombo83's Avatar
onlything i know right now is youll probably have to get a new intake manifold gasket.
Old Apr 10, 2003 | 08:01 AM
Project X's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J337_UNIT &raquo;</TD></TR><TR><TD CLASS="quote">Im going to install my Skunk2 IM soon on my 98 Integra GS, has anyone installed this item on a NON VTEC integra, If so, please tell me what items i will need to complete the install, and what kind of gains did you see. What size is the opening ? 64mm? because i plan on getting a matching T/B and a type-r aem intake.</TD></TR></TABLE>
ITR throttle cable bracket or chop the LS one down to fit.
IM ported to 64mm and match both IM and TB to avoid turbulence in the incoming air flow.
caymanjdm97dc2
Nov 4, 2006 05:46 PM
frank358fr
Oct 1, 2005 11:06 AM
rusted_eyes
Nov 4, 2003 09:44 AM
One Bad GeeSeeR
Sep 8, 2003 08:21 PM
Nocturnal
Aug 19, 2003 11:14 PM
