need help! clutch sticking.
Old Apr 9, 2003 | 12:57 AM
vtechicano's Avatar
Default need help! clutch sticking.
this is my first 5 spd. i just bought the car about a week ago. its a 92 civic cx hatch. the lady told me her husband put in the D15b8,or b7 cant remember, when the original motor went out. the D15 has about 100,xxx from what she told me. the odometer reads 214,xxx. anyways, im freaked out becuz i never owned a 5 spd. before. could it be time for a new clutch or does it need oil like when in an automatic. if so where the hell is do you put it at. i thought it might have been cold becuz a cold front came through today and its around 50 ish outside. but after driving for about 20 min, to get home, i thought it would get better. after about another 10min of driving, feels like it is getting better. but still puzzled. if it does need a new clutch, about how much am i looking at. also if it only need oil what kind do i buy. hope you guys can help me out. other than that i got a good deal and it runs good. just did a tune up and changed the brakes. ill try and post pics this weekend. after you see it you guys are going to be mad after i tell you how much i spent, the body is in good shape,too.
Old Apr 9, 2003 | 01:30 AM
RICE POLICE SIP's Avatar
Default Re: need help! clutch sticking. (vtechicano)
you might need hyd. fluid in the clutch res.
Old Apr 9, 2003 | 09:02 AM
vtechicano's Avatar
Default Re: need help! clutch sticking. (92boostn'hatch)
where do i put the fluid. come on guys thats why i asked the ? on HT i sure someone has run into this problem.
Old Apr 9, 2003 | 09:50 AM
JDMH22HATCH's Avatar
Pop the hood and to the right of the brake master cylinder you will see a smaller resevoir attached to your clutch master cylinder. Fill that will brake fluid and have somebody pump the clutch pedal while you bleed the clutch slave. The clutch slave is on the front of the motor to the left of your exhaust manifold below the block stamp. Good luck and feel free to IM if you need any help.
Old Apr 9, 2003 | 10:35 AM
Mocky57's Avatar
not to f*ck with the topic, but the clutch sticking thing reminded me...
one of the things i noticed when i was replacing fluids, etc.. was that my clutch squeaks when I press down on it. I checked the pedal and looked around for where the squeaking noise comes from, but I can't find an appropriate place to add lubricant. Any suggestions (and also, what lubricant do people use). Thanks.
Old Apr 9, 2003 | 01:58 PM
vtechicano's Avatar
Default Re: need help! clutch sticking. (Mocky57)
thanx JDMH22hatch. ya i took it to a machanic this morning and he told me i need to replace the clutch master cylinder and to replace the slave cylinder at the same time. anyone ever done this. was it hard. i have a machanic that i know wont charge me alot. just wanted to see if i can change it myself.
Old Apr 9, 2003 | 02:03 PM
PotatoePAPA's Avatar
i would def. bleed the clutch slave....happened to me after replacing my clutch because there was air in the lines... Just like JDMH22hatch said...try this before doing what the mechanic said.
Modified by EG CoUpe at 3:17 PM 4/9/2003
mikeangelo
Honda S2000
Oct 17, 2012 05:35 PM
dLe_lsbgl
13
Apr 11, 2005 11:29 AM
rough_draft
Apr 11, 2004 07:56 PM
egcivic
17
Sep 15, 2003 03:25 PM
