#4 injector not firing HELP!
Old Apr 9, 2003 | 12:15 AM
ALLmotorCRX's Avatar
Default #4 injector not firing HELP!
I just rewired the front of the car and now i think my number 4 cylinder isnt working. after like 40 seconds of operating the number 4 header pipe was cold and 3,2,and 1 were warm. spark plug was dry and didnt smell like fuel.
Old Apr 9, 2003 | 04:44 AM
Perfectionist's Avatar
Default Re: #4 injector not firing HELP! (ALLmotorCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALLmotorCRX &raquo;</TD></TR><TR><TD CLASS="quote">I just rewired the front of the car and now i think my number 4 cylinder isnt working. </TD></TR></TABLE>
Re-check your work. You missed one or more connections.
With ignition on, engine not runnung, you should measure 12 volts at both pins of the injector. If not, check back towards the injector resistors. If you only get 12 volts at one pin, the injector coil is open.
If things check out this far, briefly ground the injector pin that's on the ECU side. The injector should click. (The injectors receive a constant 12 volts and the ECU completes the circuit to ground to trigger the injectors.)
NevinJoe
Sep 17, 2025 12:50 PM
a1320honda
Sep 23, 2007 01:06 PM
OrangeBoost
May 30, 2006 10:22 AM
Vtec5500
Oct 29, 2005 02:29 PM
2.3Hatch
Mar 2, 2003 09:32 AM
