GS-R intake manifold, how restrictive?
You will get better top end gains with the Skunk, Particularly if you get more aggressive cams, but the GSR manifold is pretty good as is and the dual runner setup works as advertised. That is, it gives good low end torque.
DO NOT just remove or disable the butterfly valves in the stock manifold thinking that will gove you more power. All that does is kill your low end.
Mike
Mike
andrewxxcarlson
Nov 24, 2011 08:51 AM
