will i pass smog check with what i will do?
i'm not passing smog and i think its because of the jun chip i got...i got a new cat, new sensor, aem adj. fuel pressure reg. to control the co, nox and the hc...but it's not working too well....i would pass the 15mph test but fail the 25mph test...if i adjust the fuel so that i can pass the 25mph, then i can't pas the 15mph test...my smog check technician is also getting frustrated and is now demanding me to get my original ecu back....the problem is that i don't have one. i might be able to borrow a ecu(not chipped) from a civic or a integra ls or gs.....i have a gsr and if i do plug in the ecu from some other car, will i pass smog? anyone have similiar experiences?? the damn search thing doesn't work....also...what's the factory fuel psi for the 94gsr?
you passed the visaul test with those mods ? did your tech look past the mods and smog it ? if you have a new cat its your ecu , the jun program uses alot more gas and advanced timing , you need the stock ecu , i have a stock ecu you can borrow if worst comes to worst , is the smog tech a friend ? i might need some help soon with my smog
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92lsr »</TD></TR><TR><TD CLASS="quote">you passed the visaul test with those mods ? did your tech look past the mods and smog it ? if you have a new cat its your ecu , the jun program uses alot more gas and advanced timing , you need the stock ecu , i have a stock ecu you can borrow if worst comes to worst , is the smog tech a friend ? i might need some help soon with my smog </TD></TR></TABLE>
i used to work at the place....thanks about you wanting to letting me borrow the ecu...but you live in san diego....damn...thanks though...if you do need help getting your car smogged even if you have a bunch of mods....as long as you pass...no problem...but then again, you live in san diego, the smog place is in Arcadia.
i have a 94 gsr, but its just sitting there right now cuz i'm rebuilding a blown motor...so if you need to borrow the ecu let me know and we can work something out, im in the corona 909 area
SuperDuude
Oct 26, 2004 11:26 PM
ProudtobeANoob
Mar 7, 2003 02:53 PM
