honda accord temp problem
Old Apr 8, 2003 | 08:17 PM
jhwells's Avatar
Default honda accord temp problem
so does your honda accord temp flucuate now that you replaced your thermostat and how many miles does it have and what year is it.?mine stays in the middle and sometimes over a bit...is that normal or what....
Old Apr 8, 2003 | 08:21 PM
Razor's Avatar
Default Re: honda accord temp problem (jhwells)
since you're a new member, make sure you use the REPLY button instead of the NEW TOPIC button.
ever since i changed my thermostat, the temp gauge doesn't even move one bit. its perfect now. my accord is a 94 EX with about 68k miles.
it is not normal for the temp gauge to move around at all. if you checked the coolant level already, its most likely your thermostat. the thermostat is cheap, but the labor is kind of hard since you have to remove the intake pipe to get to the thermostat housing toward the back of the engine.
good luck.
Old Apr 8, 2003 | 08:22 PM
jhwells's Avatar
Default Re: honda accord temp problem (Razor)
thanks i was wondering about the reply thing...sorry about that ......i will try that and see if it works.....i can replace it myself....i just wanted to ask someone else....i was afraid i was being paranoid.....
Wagon1991
Jun 26, 2015 07:16 PM
lazychina
10
Jun 30, 2011 07:16 PM
RVD9431
Jan 1, 2011 07:45 PM
StuntxPuller
Jan 22, 2002 09:28 PM
