modifications for h22 in 4th gen
i have finally decided to go the h22 route. for those of u who did it, i got a few questions....
1. are there any heavy modifications needed to fit the motor in?? (any mods at all is what im asking)
2. what mount kit do i need to buy??
Peace out
Peace out
no mount kit is needed. it drops right in. the only mounts you *MIGHT* have to modify is the rear motor mount and tranny mount but they should work. if anything you would just have to grind them down a little.
some things you will need to do....
1.) make a custom PS line.
2.) convert from an internal coil (f22) to the external coil on (h22)
--- https://honda-tech.com/zerothread?id=348699
3.) wire up your vtec
i'm sure other people will have more stuff to add as well.
[Modified by smuggy, 4:41 AM 4/9/2003]
[Modified by smuggy, 4:42 AM 4/9/2003]
This topic has been covered numerous amounts of time, try using that search link up in the upper right hand corner, no heavy mods, ive heard that a few motor mounts have actually lined up perfectly and some havent.
