larbest bore able to run on stock cyl head?
Old Apr 8, 2003 | 04:56 PM
JeremyL's Avatar
Default larbest bore able to run on stock cyl head?
whats the largest bore you can run on stock b series head?
Old Apr 8, 2003 | 05:22 PM
VTEC-DA's Avatar
Default Re: larbest bore able to run on stock cyl head? (JeremyL)
You bore the block, not the head.
Old Apr 8, 2003 | 05:44 PM
Al Bundy's Avatar
You deshroud the head to align with the bore on the block
Old Apr 9, 2003 | 03:22 AM
JeremyL's Avatar
Default Re: larbest bore able to run on stock cyl head? (Al Bundy)
how do you do that? i plan on running atleast an 84mm bore with the GE sleeves
Old Apr 9, 2003 | 05:07 AM
Blk98Teg's Avatar
A speed shop needs to do that. Dont get out your dremel tool and try to do it yourself.
Old Apr 9, 2003 | 07:49 AM
JeremyL's Avatar
Default Re: larbest bore able to run on stock cyl head? (Blk98Teg)
is it that safe to do?
Old Apr 9, 2003 | 09:34 AM
VTEC-DA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JeremyL &raquo;</TD></TR><TR><TD CLASS="quote">is it that safe to do?</TD></TR></TABLE>
What a dremel? Definately not.
Old Apr 9, 2003 | 09:50 AM
dfoxengr's Avatar
if ur talking about opening up the combustion chambers u shouldnt....
Old Apr 9, 2003 | 10:30 AM
JeremyL's Avatar
Default Re: (hybridvteceg)
no i meant is unshrouding the head safe? but what is the largest bore you can run on a fully stock cyl head beofre unshrouding is needed
BMC125
Sep 12, 2013 02:41 PM
Junglesnake
Sep 8, 2005 08:17 AM
Creative911
Aug 24, 2004 05:53 AM
93H22ACX
Jun 14, 2004 05:27 AM
gelok
Feb 16, 2004 08:13 AM
