? about installing new pistons
Old Apr 8, 2003 | 01:17 PM
Vampyre's Avatar
Default ? about installing new pistons
ok i am looking at getting the toda pistons.
my ? is. i am pretty sure that i would have to bore and hone the stock sleeves for the new pistons. the stock bore is 81.25? correct? should i get the 81.50 or the 82mm? and what ever the pistons size is that what you bore the block out to?
Old Apr 8, 2003 | 01:18 PM
sgT's Avatar
sgT
Default Re: ? about installing new pistons (Vampyre)
dont waste your money, get CTR pistons instead.
FYI, stock bore is 81.00
Old Apr 8, 2003 | 01:29 PM
Vampyre's Avatar
Default Re: ? about installing new pistons (sgT)
why ctr if i plan on doing a full toda head package. 12.3:1 sounds just about right for the cams.
also would i be able to use the stock itr rods? caus i read somewhere that not a lot of aftermarket rods work with todas pistons
Old Apr 8, 2003 | 01:32 PM
sgT's Avatar
sgT
because its a waste of money. ctrs do the same job just as well for less cost.
but its your money
Old Apr 8, 2003 | 01:34 PM
Johnny Tran's Avatar
i just got a headache...your best bet is to remain stock, and do some research
Old Apr 8, 2003 | 01:39 PM
Vampyre's Avatar
Default Re: ? about installing new pistons (Johnny Tran)
i am doing research. its just that i have read that in a few places and want to confire or denie it.
sometimes this place is touchey
Old Apr 8, 2003 | 03:16 PM
jansenrw's Avatar
gimme your email and I'll email ,you some info re clearances and tolerances.. I just had to replace my pistons with toda 81.25mm.. I had the dilemma of choosing stock 81.00 or 81.25 but believe me, it will save you money in the long run... BORE AND HONE THE biatch!! Also if you have a type R we calculated the displacement to be around 1.81125 litres ( taking into consideration the original was 1.8 for simplicstic sake)
Jansen
Old Apr 8, 2003 | 11:35 PM
Vampyre's Avatar
Default Re: ? about installing new pistons (jansenrw)
you have a im
Old Apr 9, 2003 | 03:17 AM
D's Avatar
D
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jansenrw &raquo;</TD></TR><TR><TD CLASS="quote"> Also if you have a type R we calculated the displacement to be around 1.81125 litres ( taking into consideration the original was 1.8 for simplicstic sake)
Jansen
what's the point in carrying out your calculation to 5 decimal places when you rounded the initial displacement?
Old Apr 9, 2003 | 04:35 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: ? about installing new pistons (D)
There is sufficient evidence to indicate that the rate of increase in output per unit increase of input decreases as the input increases.
Old Apr 9, 2003 | 07:16 AM
Vampyre's Avatar
Default Re: ? about installing new pistons (RealTypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RealTypeR &raquo;</TD></TR><TR><TD CLASS="quote">There is sufficient evidence to indicate that the rate of increase in output per unit increase of input decreases as the input increases.
word
KnuckleZ
Sep 22, 2007 09:34 PM
Spec R_GSR
May 12, 2007 07:01 AM
DC5ftmfw
11
May 1, 2006 08:05 PM
PickleTeg
Apr 4, 2006 07:59 PM
night
Oct 2, 2004 07:05 PM
