Highest Comp on 91 Octane?????????
Old Apr 8, 2003 | 11:45 AM
AK94GSR's Avatar
Default Highest Comp on 91 Octane?????????
How much compression could I run on 91 octane pump gas????
I will be going Hondata if that makes a difference with tuning
Old Apr 8, 2003 | 12:44 PM
joe_bocc's Avatar
Default Re: Highest Comp on 91 Octane????????? (AK94GSR)
I have heard 12.5:1 is the limit with really good tuning.
I personally won't go above 12:1 just for safety.
Old Apr 8, 2003 | 04:31 PM
AK94GSR's Avatar
Default Re: Highest Comp on 91 Octane????????? (joe_bocc)
I heard 12:1
anyone else know the limits of tuning with 91 octane
Old Apr 12, 2003 | 05:39 AM
. o 69 o .'s Avatar
i have heard 11.5:1 .... maybe 12:1 if you are running 94 octane
Old Apr 12, 2003 | 01:00 PM
Quick 200k Mile Motor's Avatar
if it has knock sensor, I'd say 11.0:1
Old Apr 12, 2003 | 01:58 PM
Rob Dizzle's Avatar
Default Re: Highest Comp on 91 Octane????????? (Quick 200k Mile Motor)
I run 11.5~ on hondata
jdm itr pistons, gsr head, flat faced valves, stock headgasket
I wouldnt go higher than 12.2 or so.
Old Apr 12, 2003 | 02:03 PM
eh2666's Avatar
Blackbeautyitr runs 12.3:1 on 91 octane JUN(cosworth) pistons and 91 octane w/ both a jun ecu and now a hondata ecu. but they are forged pistons.
Modified by eh2666 at 7:56 AM 4/14/2003
Old Apr 14, 2003 | 09:12 AM
AK94GSR's Avatar
Default Re: Highest Comp on 91 Octane????????? (eh2666)
I do plan on running Hondata so maybe 11.5:1 is possible.
anyone else have any insight on this
Old Apr 14, 2003 | 04:57 PM
toooslow's Avatar
How much power increase do u get from bumping up the compression. For example, what gains would you most likely get if i were to raise your compression from 10.5:1 to 11.5:1?
Old Apr 14, 2003 | 08:21 PM
. o 69 o .'s Avatar
Default Re: Highest Comp on 91 Octane????????? (whiteinteg95)
maybe about 7-10 HP gain if you tune properly. You will notice and increase in torque. Worth it in my opinion.
Old Apr 14, 2003 | 08:26 PM
AllmotorJunkie's Avatar
I live in San Jose and 12:1 is what they are saying around here. Although some peeps that run 12:1 have premature combustion with 91 octane while some don't. Just to be on the safe side...I would recommend 11.5:1 if the highest octane you can get your hands on is 91.
Peace
Old Apr 14, 2003 | 08:31 PM
. o 69 o .'s Avatar
Default Re: Highest Comp on 91 Octane????????? (AllmotorJunkie)
Exactly!!
Old Apr 14, 2003 | 08:44 PM
RuKKus's Avatar
Default Re: Highest Comp on 91 Octane????????? (B16B)
I run about 12.3:1 using 91 octane. There's a shop out here that build an ITR with 13.1 running on 91 octane also. From what I heard if you tune it right you'll be ok with it.
Old Apr 14, 2003 | 09:30 PM
riceboy's Avatar
Default Re: Highest Comp on 91 Octane????????? (RuKKus)
I would say the limit is 11.8:1 - 12:1 with great tuning with no combustion chamber work and stock pistons, I would think that an experienced tuner with a good standalone could take it closer to 13:1 on 91 octane if the motor was built properly.
But for safety, I'd say 12:1 is the max, after that the risk versus return isnt near as great.
Old Apr 14, 2003 | 09:32 PM
TedR719's Avatar
Default Re: Highest Comp on 91 Octane????????? (riceboy)
safest I would say on 91 is 11:5:1 (that's what Celica GTS c/r is at if I'm not mistaken)
92 civic VX B18c
Dec 26, 2005 07:50 AM
Revhard92si
Jun 4, 2004 10:48 AM
chrisdansin
Jan 24, 2004 04:15 PM
Tofurky
Aug 26, 2003 11:49 PM
AllMotorITR
Sep 30, 2002 09:33 PM
