94+ integra dash in a 96+ civic?
I know it will bolt into a 92-95 but will it bolt into a 96+ hatch. that would be one cool mod to do. I am mostly a speed guy but that is one mod I would do in a heartbeat to be different.
Thanks, Dave
Thanks, Dave
that is definitely nice blaze. how difficult was it. what did you have to modify and are there any problems with the air vents, gauge cluster, etc. a couple of more things, did you have to rewire it in order to have the integ cluster fit? and how did you make the door panels fit? i need details pls. thanks in advanced.
i had to modify the door panels, use drying venting for the vents, and do alot of cutting and test fitting, cut, test, cut, test... and also some rewiring. just make sure you have the dash wire harness. for the door panels, i had to cut the plastic underneath the vinyl and reglue it back onto the plastic. it only took me a weekend but it was a weekend of headaches...
what are drying venting and how difficult was the wiring? did you restitch the door panels? excuse my ignorance. thanks.
GreenJUNKmachine
Mar 30, 2009 07:05 PM
ekekek
Feb 11, 2002 06:13 PM
