Is a tube frame car streetable ?
Old Jun 22, 2001 | 05:01 PM
Hybrid ctr's Avatar
Default Is a tube frame car streetable ?
Old Jun 22, 2001 | 05:11 PM
Hybrid ctr's Avatar
Default Re: Is a tube frame car streetable ? (Brian*Black99Si)
how much weight can tube framing save
Old Jun 22, 2001 | 07:14 PM
itrhybrid's Avatar
Ummmm. No. Not to mention illegal.
Old Jun 22, 2001 | 08:13 PM
Vazquez911's Avatar
Default Re: Is a tube frame car streetable (itrhybrid)
It'll save a LOAD... that's one of the key reasons for it...
* More ridgid
* FAR lighter...
And it COULD be street legal, if you went through the EXPENSIVE process of having it crash tested, etc... Then it'd ONLY be legal if it passed.
You catching on yet? Track only...
Old Jun 22, 2001 | 08:23 PM
Hybrid ctr's Avatar
Default Re: Is a tube frame car streetable (Vazquez911)
GOT IT
thanks
Old Jun 22, 2001 | 08:43 PM
jond's Avatar
Default Re: Is a tube frame car streetable (Hybrid ctr)
Some kitcar cobras have tube frames and they're streetlegal. Also dunebuggies are streatlegal aren't they?
Old Jun 22, 2001 | 09:11 PM
Hybrid ctr's Avatar
Default Re: Is a tube frame car streetable (jond)
what exactly is tube framing
is it totally replacing the car's structure
would tube framing an R totally change it's handling abilities
Old Jun 23, 2001 | 07:40 PM
Its_real&its_spectacular's Avatar
New User
Tube framing oversimplified. Start with tubes, tape measure, bender and a mig welder. Cut, bend, weld tubes until you have something that looks vaguely car shaped (In the same way as a skeleton is human shaped). Mount motor, suspension, seat(s) and body panels to tube frame. Take to racetrack and destroy all who oppose...
It can be done so that stock suspension mounting points are retained so handling will be similar to stock, though weight will be soooooo much less that it will be quite different. Most tube framed cars will also have VERY adjustable suspension that has little in common with stock.
I'm pit crewing for a car (Fiero but tube frame based) that'll weigh in at around 2000 lbs (maybe 2100) with a 4.3L V6 putting out a minimum 450 hp. It's gonna be fun!!!
BLU CIVIC
Dec 24, 2008 07:13 AM
civic.slow
Welding / Fabrication
10
Nov 25, 2007 12:42 AM
sik94hatch
12
May 19, 2005 10:43 AM
AussieK24
May 9, 2003 09:35 AM
Adam.
12
Sep 11, 2002 06:35 PM
