going on third distributer cap jdm b18c problems
Old Apr 8, 2003 | 04:17 AM
bodydropranger's Avatar
Default going on third distributer cap jdm b18c problems
okay here goes. what is the deal are the vendors idiots or am i buying the wrong parts??
1st cap=from napa, mounting holes and actual cap to large
2nd cap= from acura, mounting different and cap to large same cap as above
wich cap do i order??? the motor is a jdm gsr motor it is i believe a 94 i cannot locate the right cap. please help
Old Apr 8, 2003 | 07:08 AM
eg6ajk's Avatar
Default Re: going on third distributer cap jdm b18c problems (bodydropranger)
i had the same problem. I order one off a B16A (Del Sol VTEC) it didn't work then got another one ( I think ITR or obdII GSR ) and it worked fine
Old Apr 8, 2003 | 07:23 AM
colt45.5's Avatar
Default Re: going on third distributer cap jdm b18c problems (eg6ajk)
So what you are saying is the jdm engines obd1 use the same cap and rotor button as a obd2 b series vtec distributor?
Old Apr 8, 2003 | 08:09 AM
RareSI's Avatar
Jesse, I did some checking while at work today...
96-00 Civic (except HX)
P/N: 30102-P54-006
H/C: 424793
95 del Sol (VTEC)
P/N: 30102-P54-006
H/C: 424793
94-96/99 Integra GS-R
P/N: 30102-P72-006
94-96 Integra LS, RS
P/N: 30102-P54-006
97-98/00-01 Integra GS-R, Type-R
P/N: 30102-P72-006
As you can see, the Integra LS/RS shares the same part # as what's used on the B16a's. However, the GSR and Type-R are using another part. I don't see why they aren't interchangable, but there seems to be different part #s for a reason.
[Modified by RareSI, 12:17 PM 4/8/2003]
Scott51692
Jan 13, 2018 04:30 PM
crazyguy
Aug 20, 2007 06:48 PM
hackish
Feb 28, 2006 10:06 PM
Dan GSR
Jan 25, 2005 11:54 PM
shivic
Oct 6, 2003 07:07 PM
