help 3rd gear 1k good 2 k good 3 k and plus???
ok first of all i dont think my oils been changed in a while i just got the car though and at first it was fine after getting use to manual transmisions and the ocasional miss shifts my car tends to grind in third gear? this is weird because it only does it after 3000 rpms and up ? it takes it in fine and all the other gears are good just grinds 3rd ? can some one help? a friend tells me a sinchro ? if any one knows can u please state the prob and maybe an estimate cuz i know sinchros r a bitch to fix and are very expensive thanks in advance .
so first change the fluid and if that doesnt do the trick then rebuild or get a new tranny ? or change out the sinchro
i think its your synchro too.
i also agree with 97hb. the synchro kits i've seen per gear is around $100. the big thing is getting to that synchro just so you can change it out. if you plan on dropping your tranny and taking it apart yourself, make sure to get a manual.
Rpizzle
Apr 11, 2005 03:24 PM
Nerologic
50
Nov 3, 2003 05:37 PM
