help with timing belt
Old Apr 7, 2003 | 08:35 PM
g5r's Avatar
g5r
Default help with timing belt
i just check my timing with a timing gun and i found out that the white mark jumps like every other second, sometime it line up with the mark on the cover and sometime it dont. can anybody tell me whats my problem is? thanks
Old Apr 7, 2003 | 08:38 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: help with timing belt (g5r)
Did you follow the correct procedure for checking the ignition timing, including warming the car up to operating temperature, and then jumping the diagnostic connector behind the pass. side kick panel (very important)? You have to use a jumper wire on the connector, which puts the ECU in diagnostic mode, which in turn keeps the ignition timing constant. Normally the ECU will adjust ignition timing while the car idles to help keep the idle as smooth as possible.
Old Apr 7, 2003 | 08:49 PM
g5r's Avatar
g5r
Default Re: help with timing belt (PatrickGSR94)
my car is a 2000 gsr and i dont have a connector for a ECU diagnostic. however my friend`s SI which have the connector, he check his timing with and without the connector. his car timing didnt jump.
Old Apr 7, 2003 | 08:51 PM
Community Builder
Are you sure about that? You don't have a 2-wire diagnostic connector tucked up near your ECU in the pass. side kick panel? I think you should have one.
eg grom
Jun 25, 2009 09:27 PM
umair
Oct 16, 2008 10:34 AM
smash fascism
17
Sep 14, 2005 07:02 AM
g5r
Apr 7, 2003 10:08 PM
Boostless97Lude
Jan 7, 2003 08:24 AM
