rear disc brakes?
I've heard that you can pull the rear discs of an integra and stick on to a civic. has anybody ever swaped it? if so what year integra and which parts did you pull?
p.s. I've got a 91 si hb
ya it's a good upgrade to the brake system
here is the best thing to do. Use the SEARCH up in the right side of the screen
there is a lot of info there
[Modified by EFrollingout, 5:46 AM 4/8/2003]
https://honda-tech.com/zerothread?id=468609
everything you need to know, hopefully...........
the be all, end all of brakes
https://honda-tech.com/zerothread?id=152884
yeah man i did the swap from a 91 teg to my 91 civic hatch its really easy to do and they work great too. but if u can.. get the fronts also. although then u must run at least a 14 inch rim for proper clearance .. definatly a cool mod
Can you really use 94-01 integra rear brakes on an ef? I thought it was only 90-93 tegs. Would you need exactly the same parts from the 90-93 as you would the 94-01?
mario_pic
Mar 27, 2008 11:10 PM
Josh22999
Mar 28, 2007 10:30 AM
