[FAQ] ECU Codes and trouble shooting
Old Apr 7, 2003 | 07:30 PM
zCivic's Avatar
Default ECU Codes and trouble shooting
Due to we-todd-did sucking I'm going to a new host. Rebuilding at this time just slow going sorry
Modified by zCivic at 9:13 PM 2/6/2007
Modified by zCivic at 9:17 PM 2/6/2007
Old Apr 8, 2003 | 08:48 AM
Kg cm2's Avatar
Default Re: ECU Codes and trouble shooting (zCivic)
would a code 0, be displayed with just a check engine? Like will it not blink out the code. We'll say on a obd1 gsr ecu. What do you think?
Old Apr 8, 2003 | 12:20 PM
importfan85's Avatar
Wow, excellent post. This will help a lot of people in the future
for you
Old Apr 25, 2003 | 09:53 AM
CivicBoi's Avatar
Best post
Old Jul 19, 2003 | 12:34 PM
RCautoworks's Avatar
Default Re: ECU Codes and trouble shooting (crxboi)
This should become a sticky.
Old Jul 19, 2003 | 12:41 PM
DohcVtecCrx's Avatar
Here is a link to the uk honda service manual that includes the vtec suplement.
http://www.acute.f9.co.uk/crx/...s.htm
Old Jul 19, 2003 | 12:53 PM
zCivic's Avatar
Default Re: ECU Codes and trouble shooting (Kg cm2)
Code 0 I still have yet to figure out.....I think its where your CEL doesn't come on when you turn the ignition on(while the fuel pump is going) or its when the CEL remains on but that in my case was caused by a bad ROM set. Truthfully your guess is as good as mine. I need to add the v-tec supliement I have it just not much free time right now....
Old Jul 19, 2003 | 06:05 PM
code 0 is ecu malfunction
Old Jul 24, 2003 | 01:43 PM
silverkorn's Avatar
a code 0 is a bad ECU, therby being in limp mode, not allowing to rev past a certain rpm, 4k i think?
now i was told that a long blink means 10, is this true or does it blink 10 times?
Old Jul 25, 2003 | 03:15 AM
zCivic's Avatar
Default Re: (silverkorn)
long blink or 10 blinks both are the same just depends on the ECU. Most OBD0 flash 10 times ex. PR3 use the long flash I know unsure about PWO
Old Aug 29, 2003 | 11:39 PM
Vinceg99's Avatar
Default Re: (zCivic)
Well its an older post but not too old just had to bump it to get it out of the archives since its great post!!
Old Oct 22, 2003 | 08:09 AM
keithv's Avatar
Randy, those codes listed above have to images. A PDF will always open in a Adobe Acrobat which is a different program and not openable right through Internet Explorer.
You could open the PDF to the right page, take a screen shot of the page and save them as a picture. If you need some help with this, let me know.
Old Oct 22, 2003 | 11:53 AM
SOHCrx's Avatar
Default Re: (keithv)
this post has been helpful to me.. gave me more info about my code 1 then the manual did and now i can hopefully fix it... yeaaa
Old Oct 22, 2003 | 02:23 PM
zCivic's Avatar
Default Re: (SOHCrx)
Finally we have V-TEC enjoy.....Like B4 if something is wrong I/M me and will fix it
Old Oct 29, 2003 | 07:45 AM
importboi22's Avatar
hopefully code 7 will be gone today
Old Jan 20, 2004 | 08:44 PM
LegoZ81's Avatar
bump VERY good info!
Old May 16, 2004 | 05:16 PM
BR's Avatar
BR
Big props to zCivic for the best thread I have read in ages. This is by far the largest amount of useful information I have stumbled across in ages.
Later,
BR
Old May 20, 2004 | 05:48 PM
berettagtz117's Avatar
Default Re: ECU Codes and trouble shooting (BR)
Nice post I have been trying to find this **** out forever.. Thanks
Old Jun 15, 2004 | 04:46 PM
EVIL_AWD's Avatar
Default Re: ECU Codes and trouble shooting (berettagtz117)
Well I still dont know what code my ECU is trying to give me. I have a 1991 Civic EF STD. I get one blink, then a pause then another blink and a pause and then 16 quick blinks. Then it repeats itself all over again. So is this code 20 and 16? I know on my Integra you cannot get more the 9 quick blinks and that's why I'm being thrown off by the 16 quick blinks. Can someone hlep me out? Thanks in advance.
Old Jul 2, 2004 | 12:00 PM
zCivic's Avatar
Default Re: ECU Codes and trouble shooting (ITR420)
could be 20 and 16.... some ECU will count 10 as long blinks others will count them as 10 quick flashes...flashes being quicker then blinks in my crazy world. if your getting 16 and there quick flashes all together are the 2 blinks the LED staying on longer if so those are 10's.
Old Aug 12, 2004 | 08:54 PM
sinfultrends's Avatar
hmm my check engine light goes on when i take long trips and rev past 4K checked the ecu later on that night (CEL not on anymore) it just has 1 steady blink somewhat long? dont have anything to compare it to. could this be a code zero?
Old Aug 13, 2004 | 10:20 PM
zCivic's Avatar
Default Re: ECU Codes and trouble shooting (sinfultrends)
its not a 0. a 0 the LED light will stay on constantly, not flash, blink and run like absolute crap. If its kinda long and it repeats itself it probably a 10. _____pause 5sec_____. Or is it _pause 5sec_ then its a 1. Or it could be _____ _____pause 5sec_____ _____ which would be a 20 or if its _____ _ _pause 5 sec _____ _ _ would be a 12 etc....and some ECU PM6's PG7 for examples usually dont do the long blinks, for 10, will flash _ _ _ _ _ _ _ _ _ _pause 5sec _ _ _ _ _ _ _ _ _ _. Hope this helps
Old Aug 24, 2004 | 06:49 AM
raymas8's Avatar
how do you check for codes with a b16a ecu that does not have the led on the ecu?
Old Aug 25, 2004 | 03:09 PM
zCivic's Avatar
Default Re: ECU Codes and trouble shooting (raymas8)
If its OBD1/2 theres a jumper harness, usually on the passengerside kick panel. Jump it and it will cause your ECU to flash. The same way the ECU LED does.
Old Aug 25, 2004 | 04:55 PM
1990hondadx's Avatar
i have one blink short pause blink short pause blink short pause would this be code one?
