1996 Civic EX with a PRELUDE swap
i am interested in some answers of the following in my swap.
What type shifter to buy...civic or prelude?
Do i need a new radiator?
Cold or ram intake?
What type break system?
and any other reccomendations! thanks alot
Cold or ram intake?
I recommend you wait around a read before undertaking this swap.
Also, cuddle up nice and close to your Helms every night to get more affiliated with this stuff. You don't seem to be a tech expert.
You need the entire shifter cables and shifter assembly from a Prelude or Accord.
You've gotta cut two small holes, and run the cables down through one of them
Cold air. Del Sol VTEC radiator. 11" Fastbrakes upgrade, good shocks, and some good springs.
I don't mean to hijack this thread or anything, but I seek much of the same information as the orginal poster.
I will be swapping a H22 into my '96 EX soon and I have a few questions.
1) If I use the HCP mount kit, what shift linkage will I need? Custom made or what?
2) Will I need a new throttle cable, or do I need to modify the existing one? Or neither?
3) What hoses (radiator, etc.) will I need? Or do I need to cut some?
4) Will I be able to keep my power steering with the HCP mount kit?
I was going to make my own topic, but since this person is researching the same thing as I, I thought I'd ask here first.
[Modified by Kyoji, 3:02 AM 4/9/2003]
2) Not sure, dont think so
3) Upper radiator hose: 90 teg LS
Lower radiator: 94' Del Sol Vtec
4) i hope so, but not sure
im 2 for 4, anybody else follow that up?
1) You'll need shift cables from a 91' or above accord or prelude. and assembly
2) No clue. Probably not. Just run it to the bracket and tuck away the excess somewhere.
3) What he said.
4) You'll probably need to re-do the Civic's PS hose to fit the H22 PS pump. (Just run w/o it, build some muscles!
)Trending Topics
)Thanks for all the info, I've been trying to make this swap as painless as possible.
and
to all.[Modified by Kyoji, 4:16 AM 4/9/2003]
Boosted Power
May 17, 2021 02:07 AM
Twilightepitaph
Texas -OK -LA (Sales)
Nov 30, 2007 06:44 PM
rycbrnr81
Feb 20, 2007 11:01 AM
paulzy
Nov 22, 2005 03:03 PM
Boosted Power
Aug 16, 2005 06:18 PM
