Rollin fenders??
Old Apr 7, 2003 | 03:40 PM
hitekper4mance's Avatar
Default Rollin fenders??
Any suggestions and or tips on how to roll the fenders on a 94 integra hatchback?? Anything will be helpful. Thanks!!!
Old Apr 7, 2003 | 03:58 PM
xrocket21's Avatar
Default Re: Rollin fenders?? (hitekper4mance)
Use a baseball bat the bend it and roll it under, do a search, im suretheres instructions somewhere, i just read an article about it, cant remember where though.
Old Apr 7, 2003 | 04:16 PM
Default Re: Rollin fenders?? (xrocket21)
Thanks... I heard that too.. but never had the guts to do it. Does anyone know any more about this?? use the thin end, fat end, what part do you start on with the car ?? Thanks people.!
Old Apr 7, 2003 | 04:46 PM
dfoxengr's Avatar
yep a bat... be gentle though obviously
Old Apr 7, 2003 | 04:52 PM
Default Re: Rollin fenders?? (hybridvteceg)
ok....thanks.... still looking for more info though.... do you go front to back or back to front....if anyone knows the exact procedure....THANKS ALOT!!!
Old Apr 7, 2003 | 04:59 PM
dfoxengr's Avatar
put it in the well, and push the handle down
Old Apr 7, 2003 | 05:12 PM
Haha. Some more great info... I guess to do that I would have to jack the car up right?? I guess I should have said that I would like detailed or descriptive info on how to do it. Thanks!!
Old Apr 7, 2003 | 05:13 PM
dfoxengr's Avatar
yep, jack it up
Old Apr 7, 2003 | 05:36 PM
mjrage's Avatar
Actually, I wouldnt jack it up. I rolled mine by actually putting the bat in the well and then instead of pushing hard, just gripping tight and as a friend rolled the car forward, I turned the handle. Then cover the wheels and sprayed sealant.
Old Apr 7, 2003 | 05:49 PM
Default Re: Rollin fenders?? (mjrage)
what did you use the sealant for ??
Old Apr 7, 2003 | 05:56 PM
mjrage's Avatar
When you roll it, more than likely the paint will crack on the under side by where the actual lip of the fender. I sprayed sealant to prevent any paint chipping or pealing in the future., etc..
Old Apr 7, 2003 | 06:54 PM
Briman2021's Avatar
sorry to barge in on your thread, but i have heard a lot about rolling your fenders, but what exactly does it do to the fender. fold it under, make it stick out??
I have heard it is for better wheel/tire clearence, how does it work??
Thanks!!
Old Apr 7, 2003 | 07:07 PM
mjrage's Avatar
Default Re: Rollin fenders?? (Briman2021)
Run your hand under the fender and you will notice a L <--graphic When you roll it roll the _ up to more like a / that way you can get better clearance. Shops around here also cut the _ completely out.
Old Apr 7, 2003 | 07:57 PM
thanks for the info. I tried it a little bit tonight....I noticed that the paint definitely cracks off.... Just hope that I rolled it enough and that the paint doesn't dontinue to peel off towards the actual paint on the car. Only chipped off on the lip part.
Old Apr 7, 2003 | 10:51 PM
martini's Avatar
http://www.vtec.net/articles/view-ar...rticle_id=3511
Old Apr 8, 2003 | 08:51 AM
PupaScoopa's Avatar
Default Re: Rollin fenders?? (martini)
Two tips:
Heat the paint so it doesn't crack.
Use a real fender roller that attaches to your hub.
Old Apr 8, 2003 | 08:55 AM
Default Re: Rollin fenders?? (PupaScoopa)
where would you get a real fender roller for use. Don't need to buy one for 10 min of use.
Old Apr 8, 2003 | 09:07 AM
martini's Avatar
I believe Tirerack rents out a fender roller, but there is a long waiting list for it. You'd have to call them up..
Old Apr 8, 2003 | 09:13 AM
Stew Pidasso's Avatar
Also, you could cut small notches in the _ part to relieve some of the stress. When you bend it up on that radius, it's going to be "stretching" a little. This way you would be less likely to peel the paint...
In other words when you bend the _ part of the L to look like this |/ the / part will have to be "stretched" or notched because the top of / will actually be longer over this radius now.
RedneckRicer
Nov 14, 2009 09:57 PM
snapper1978
Oct 24, 2006 07:23 AM
svmnredracr
Apr 26, 2004 06:08 PM
TKFangBoy1
Jul 11, 2002 12:57 PM
Taco Sauce
May 18, 2002 07:43 AM
