B16 probs
I just got my b16 running
i have a pr3 ecu and im getting a code 1 and 4 does anybody know what these are ?
i dont have the 02 sensors hooked up just yet so im know one of the codes is the sensors.
any help would be cool
thanks
thanks
Yeah it is a 91 dx and had to do the dual port to mpfi swap
but i think i messed something up, it was running fine but now it wont start. it turns over and it sounds like the main relay is going ******* nuts
so the cps is that the crank sensor ?
I forget what wires it is truthfully at work right now and no access to manual
. I know the white wires in the Diz if there xed up will crank and not start so swap those around first. If that doesn't work will get home and look and post/i/m you with what I can find out
Thanks for the help man,
im going to try and find out the problem tonight using the diagram you gave me.
i'm just a little confused though, the car was running though, even with the code 1 and 4 it would just bogg a little from running rich.
but now the car wont even start. it will turn over but wont start.
when i turn the ignition over the main relay starts buzzing like crazy like somethings wrong or its shorted out, and then it wont turn over. its real frustrating because it was running and now its not.
any ideas you guys might have that i haven't thought of ?
ps thanks
Dan,
ps thanks
Dan,
check the resistance between all 6 pins in the Diz make sure there all within specs. That diagram list for the 2 middle pins you check the 2 above and below and the ohm should be the same 350-500. Did you swap any wires since it last ran?? My sig has the ECU link in it just click and it has alot that may help you
Actually i had a friend do the wiring
i haven't swapped any wires since it last ran
going to have to see if i can figure it out myself. if the crank sensor determines the injector pulses thats probabally why its not starting, lack of fuel. it does turn over though and try to start.
im going to pull the fuse to reset the ecu, mabey it will start so i can atleast **** with it for a bit.
again thanks for your help man.
I had the problem when I first did mine I had some pins wrong. run thru all the wiring again make sure everything is correct. I spent two days over 1 little mistake had to many wires connected opps
Good so im not the only one who has had probs wiring up a b16.
did you have the problem with the main relay as well ?
the main relay is just to the left of the drivers fuse panel, anyway the relay is clicking on and off so fast it sounds like a buzzer
its really starting to **** me off
again thanks for the help. im still at school but i can't wait to get home to **** with it.
TiMMaYBoYiE
Apr 27, 2005 06:14 PM
scoobyghost
Jun 19, 2004 12:21 PM
