Calling out V-AFC Gurus!!! Need help on tuning for N/A
Old Apr 7, 2003 | 09:49 AM
Sirex's Avatar
Default Calling out V-AFC Gurus!!! Need help on tuning for N/A
I just got a D16Z6 engine in my 1991 crx si. im using an msd rpm activated switch to trigger vtec but i dont have any fuel settings in high cam and the pm6 ecu maps are the sux!!
I ordered a v-afc and i was wondering if any had any suggested settings for a more aggressive fuel map for this sohc vtec engine..
thanks guys.
Old Apr 7, 2003 | 10:22 AM
89JDMcrx's Avatar
Default Re: Calling out V-AFC Gurus!!! Need help on tuning for N/A (Sirex)
You have to get your car dynoed.
Old Apr 7, 2003 | 10:47 AM
Sirex's Avatar
Default Re: Calling out V-AFC Gurus!!! Need help on tuning for N/A (97exracer)
see thats the thing i dont wanna dyno it i cant afford to dyno yet im going turbo ill dyno it then i just want some half decent settings to use for a month or two on a bone stock engine.
just to have it run similar to a p28 ecu rather than the crapy pm6
no im not wiring to obd1 yet.
Old Apr 7, 2003 | 04:30 PM
tinkerbell's Avatar
...you use the bone stock settings!
no gains to be had unless you have airflow changes...
but if you are trying to emulate another ECU's maps, then you will only be guessing...
dyno is the only answer
t..
[Modified by tinkerbell, 11:32 AM 4/8/2003]
Old Apr 7, 2003 | 05:43 PM
VTECVillain's Avatar
Exaclty! Doing it yourself is basically taking a stab in the dark.
Old Apr 9, 2003 | 11:02 AM
Noe Kozz's Avatar
Default Re: Calling out V-AFC Gurus!!! Need help on tuning for N/A (VTECVillain)
I hit the dyno today on the hatch, I had the vafc tuned to lean with consistant pressure throughout the powerband (no huge pikes or dips). I managed to pull an unbelievable amount of horsepower from the mighty and monstrous stock D16Z6 of about 114 HP with 96 TQ!!! lol, well she's stock for now, so it's basic settings, my peak meets at around 6,000 Rpm's. Anything after that and the torque starts to go down. Swap comming soon.
Old Apr 17, 2003 | 11:48 PM
Sirex's Avatar
Default Re: Calling out V-AFC Gurus!!! Need help on tuning for N/A (Noe Kozz)
ttt
Old Apr 18, 2003 | 08:41 AM
pills_PMD's Avatar
basically, w/out a dyno it is useless, but if anything i would say lean it out 5% and see how it *** dyno's ..
Old Apr 18, 2003 | 11:31 AM
Sirex's Avatar
Default Re: Calling out V-AFC Gurus!!! Need help on tuning for N/A (pills_PMD)
-5% throughout entire rpm band?
H22Honda98
Aug 4, 2007 10:39 PM
sagron69
Mar 18, 2004 02:11 AM
MugenB16A2
Feb 9, 2004 09:43 AM
Sirex
Apr 17, 2003 03:34 PM
