D16A6 Vs. D16Z6 bottom end
Ok, i have a question about the bottom ends of the D16a6 and D16z6. I have both complete engines. I was wondering which is a better bottom end? I plan on building a motor for my CRX. Obviously I'm going to us the Z6 head, just wanted to know which bottom end you guys think that I should use.
Thanks in advance.
Thanks in advance.
i havent investigated this so its basically here-say, but i have heard it before… vtec blocks have better webbing cast into them. so i say go with the Z6 block, there migth be a difference in the oil jet in the block that feeds the head.
NOPe! the D16a6 block is stronger just ask Wil @ exospeed... he's a true D16 harcore fan. Also the D16a6's block guirdle is much stronger for higher reving.
after looking at pics of teh a6 girdle in my manual it looks like the mains are seperate from the actual conectign piece, unlike the z6 girdle which is one piece. is that true? if so i would think that one piece would be better than 6.
hey wil help me out here... bro
who cares really yo, D16 is still a 1.6 unless you do some really craxy mods to it, your performance should be very different at all.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4thGSi »</TD></TR><TR><TD CLASS="quote">I heard they are pretty much identical.</TD></TR></TABLE>
not really
i have taken my Z6 apart for rebuild... and while i was at it i came across some few parts from a A6...
sorry i dont have pics, but the rods on the Z6 are more ticker than the A6 ones.. also the pistons are differecnt, bc of having the indents for the valves while on VTEC... the crank aparently its the same, but the block its quite a lil bit more stronger on the Z6 since i can hold more high rpms than a A6....
not really
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorman »</TD></TR><TR><TD CLASS="quote">i prefer the si bottom end,it has steel main caps versus aluminum on the z6 block</TD></TR></TABLE>
This is why I like the A6 better.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorman »</TD></TR><TR><TD CLASS="quote">well i ran 26psi on a high mileage a6 bottom end,and trust me its not the block that you will have a problem with.its the rods!!!!!! btw it went 11.54@ 126 mph
lol how ironic considering his name
</TD></TR></TABLE>lol how ironic considering his name
