Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Harness mounting in EG hatchback
Old Apr 6, 2003 | 07:02 PM
ChiBoy's Avatar
Default Harness mounting in EG hatchback
I have a couple of questions about harness mounting:
1) What do people do to mount the lap belt portion with factory seats? I've heard of people mounting the harness to eye bolts in the stock seat belt mounting points. If this is true, what thread is needed, and where can the bolts be found?
2) There was a post a week or 2 ago with a link to a harness manufacturers web site that had installation instructions with diagrams. I searched but couldn't find the post. Anyone remember the post, and if so, can you provide a link?
TIA,
-G
Old Apr 7, 2003 | 05:00 PM
ChiBoy's Avatar
Default Re: Harness mounting in EG hatchback (ChiBoy)
bump
Old Apr 7, 2003 | 07:51 PM
travis's Avatar
Eye bolts to the factory mounting points is great. Otherwise, drill your own hole and use a washer (inside) and a backup plate (outside) and double nut. Be sure to mount at the proper angle. Nearly all seatbelt bolts are universal in size. Try racerwholesale.com or any similar racing shop for hardware.
TIA,
-G
Try the (missing?) FAQ sticky, or check out soloracer.com for some diagrams.
Old Apr 8, 2003 | 08:44 AM
scott_freedman's Avatar
is ths for auto x or road race.
if yuo do scca or tsscc you could do like ma nad hte boranski sisters did.
email me privatley and we can talk.
Im in brookfield.
Old Apr 8, 2003 | 08:59 AM
JeffS's Avatar
The outside mount can screw into the factory location. Since the inside stock mount is on the seat, this won't work. You'll need to drill a hole - usually through the exhaust tunnel, and back it up with a metal plate.
The "standard size" eyebolt screws into the factory location.
You can buy them individually anywhere that sells harnesses.
http://www.ogracing.com/eshop/itemdetail.asp?itemid=742
Or they will be included if you purchase the "snap-in" mounting hardware.
Old Apr 8, 2003 | 09:54 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
Default Re: Harness mounting in EG hatchback (JeffS)
Cool. I was wondering if this is what most people have been doing. I have a mount on my seat bracket for my seat but the eyebolt interferes with the slider when installed.
Time to break out the drill.
Old Apr 8, 2003 | 11:13 AM
acura_typer's Avatar
Banned
Why won't the inside one on the seat work?
JDMequalslife
25
Apr 28, 2014 12:58 PM
AWD: Jeff
Apr 12, 2006 05:35 PM
Doctor CorteZ
12
Feb 11, 2003 12:48 PM
ITRacer121
Apr 22, 2002 01:38 PM
