Cars stalls since i install my CTR intake manifold
I would check the TPS and MAP connectors.... Make sure you got everything connected... If it's not something as simple as that maybe check to see if the MAP sensor is stuck... I have seen this happen to the point where it does not see vacuum... Did you install a new IN manifold gasket... Any CEL??? Latez
RacingRio88
Jul 7, 2005 04:50 PM
SexySI
Dec 18, 2003 11:02 PM
