Help w/install of Venom Intake Manifold
I'm in need of some wrench advise regarding how to install a Venom Drag Intake Manifold on my 97 EX. The IMF doesn't come with the standard OEM sensors connections, nor installation instructions. So, can a brutha get sum assistance? Peace...
Re: Help w/install of Venom Intake Manifold (RacingRio88)
Couldn't you just look at your current manifold, and look at theirs and just move the sensors over? Wouldn't it come predrilled for the sensors to be mounted? Or did I misunderstand you.
Re: Help w/install of Venom Intake Manifold (Maness)
I checked all that... But, from what I can tell the picture shows pre-drilled holes on the back top, which are probably for the MAP sensor and/or TPS. But I'm not sure. Other than that there are no external connections for fuel pressure hose that is connected to the fuel line. I've provided a picture of this item below from ebay. Take a look at it and let me know what you think, thanks.
http://cgi.ebay.com/ebaymotors...&rd=1
Custom drilling and tapping is required in order to utilize all factory sensor positions and auxiliaries
that is from the site, read before you purchase, its just a blank piece...lol that sux bro
also btw, your map is on ur t/b or on your firewall and your tps is on your t/b
Re: Help w/install of Venom Intake Manifold (99blackcivicSi)
YadddaaYaddaaYadda... I know that fella's... So, is there anyone out there who has purchased one of these Intake Manifolds and successfully installed? If so, can you help regarding the how to? Thanks.
perseverance
10-31-2006 10:15 PM
delslow94
04-10-2003 11:00 AM
