b20, ned h-t help.
Old Apr 6, 2003 | 06:43 PM
TheAutoboxer
Guest
Posts: n/a
Default b20 swpa in a auto sedan. need help
Ok guys.. i'm getting a 3 grand loan, 99 civic sedan, so far the car is clean, dropped,(slammed) and doing white 16" circuit 8's with neo gen v2's. The dx engine is weak, and i have the money to do a swap. The b20 install, with an auto-tranny is my first pick. Where can i get the block, tranny, ecu, axles, and cables from, also what are some questions i should be asking when looking for a garage,
parts needed >
b20 block/head,
94+ integra axles,
ls tranny, 94+
b20 ecu,
intake/header/exhuast/power pully set/cam gears
what to ask,
how long have you been in bis,
curent swap owners, time it took, problems, contact info
buiness liceans copy
and get person with the mechanic and get a vibe of condifence with his ability to swap.
my question is, what am i missing, what to expect, and ANY help.. this is a big project and anything anyone can do to help me with getting the most out of this please do. also whats the hp stats on the b20 ? and should i get a b16 head ?
ohh , btw don't ask me to get a new car, or 5speed. For some of you that know i don't have a left leg.
[Modified by menkio, 3:44 AM 4/7/2003]
Old Apr 6, 2003 | 07:10 PM
kholmes's Avatar
Default Re: b20 swpa in a auto sedan. need help (menkio)
Hey, Im in the same boat your in man. I have a 98 Civic hb that Im going to drop a b20 in. Except Im going to do the drop myself. The only place I found to get the motor is hmotorsonline.com. They have a long block for $740 plus ship. But it doesnt include tranny, alt, and axles. Dont need the tranny or axles but not sure if they will supply the ecu. Im going to call them in the morning to see. Anyway, thats the only place I know of.
Old Apr 7, 2003 | 05:17 AM
TheAutoboxer
Guest
Posts: n/a
Default Re: b20 swpa in a auto sedan. need help (kholmes)
you find out what they provid?, and as far as i've learnt a b20 block is basicly a better ls engine, i just wanna get as much info as possible.
Old Apr 7, 2003 | 04:53 PM
Blaze45's Avatar
Brrraaaap!
the B20 has weaker sleeves then the LS motor. 7mm vs 9mm. Make sure you get the higher compression motor identify it here.
https://honda-tech.com/zerothread?id=460954
PS if you do do a CRVTEC dont rev past 8k cause the cams wont make power that high. And dont buy the pully setup cause it will make for premature wear of crank journals supposedly and its hard on somethin else, just cant remember... you also might want to have your tranny built by force 10 if you are goona pump out some mad HP figures.
[Modified by Blaze45, 1:55 AM 4/8/2003]
[Modified by Blaze45, 1:56 AM 4/8/2003]
[Modified by Blaze45, 1:58 AM 4/8/2003]
Old Apr 7, 2003 | 07:54 PM
TheAutoboxer
Guest
Posts: n/a
Default Re: b20 swpa in a auto sedan. need help (Blaze45)
im thinking about just a turbo sohc d15y7 with the 78 head. This is getting to expensive
Old Apr 8, 2003 | 03:49 AM
sparq's Avatar
Its not that expensive, I could get you a B20b package for about $1600 shipped to your door. Not too bad I think, that would be motor, transmission, alternator, distributor, harness, intake/exhaust manifolds, all required cables and sensors and the ecu + shift linkage/cables.
Old Apr 13, 2003 | 04:52 AM
TheAutoboxer
Guest
Posts: n/a
Default Re: b20 swpa in a auto sedan. need help (sparq)
with an automatic tranny ? and auto ecu ?
Old Apr 13, 2003 | 01:33 PM
sparq's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by menkio &raquo;</TD></TR><TR><TD CLASS="quote">with an automatic tranny ? and auto ecu ?</TD></TR></TABLE>Yup, let me just call around to find one. Hit me up with an IM/Email
nickt@redime.com
Old Apr 13, 2003 | 07:08 PM
eg686's Avatar
im planning on b20VTEC also. im gonan buy the b16 changeover form hml and go to a junkyard to buy a b20 engien.
kchavira520
Oct 21, 2014 07:09 PM
gwilguy
Sep 7, 2008 09:33 PM
4drRacer
Sep 3, 2002 06:07 PM
