a wideband thought?
Old Apr 6, 2003 | 06:14 PM
dfoxengr's Avatar
Default a wideband thought?
arent the 5wire O2s widebands? like VX's..
red, yellow, white, orange, black?
if so ynot just plug these in for ur "tuning" session into your sencond bung if u have one or for these purposes...blah, or whatever, hook up all the wires to heater...signal, etc...(COULD SOMEONE LIST WHAT THESE OTHER WIRES DO)
and measure with a good volts meter or some device, the voltage through the powerband?
obviously no logging or stoich readings and no LAMBDA display but 1 volt is stoich so aim for that with your tuning system?
[Modified by hybridvteceg, 10:15 PM 4/6/2003]
Old Apr 6, 2003 | 06:33 PM
vactor's Avatar
Default Re: a wideband thought? (hybridvteceg)
you need the wideband controller as well. then measure the output voltage from the controller.
Old Apr 6, 2003 | 06:35 PM
dfoxengr's Avatar
Default Re: a wideband thought? (vactor)
what does the controller do that a simple volt reader cant? i have no idea about this stuff, lol
Old Apr 6, 2003 | 06:38 PM
vactor's Avatar
controller provides propoer voltage and signal for heater and has the proper conversion for sensor raw outpout
Old Apr 6, 2003 | 06:39 PM
dfoxengr's Avatar
why cant you just send thr right voltage to the heater, and u dont really need a conversion if u know the raw volt numbers correlation to the LAMBDA scale right? does neone know the correct volts toi the heater, should be 5 or 12 V right, which you can get through constant power.
Old Apr 6, 2003 | 06:47 PM
vactor's Avatar
do some reading here http://www.diy-wb.com/info.htm . you need a driver circuit.
Old Apr 7, 2003 | 03:03 AM
dfoxengr's Avatar
ahh i did read there..but its confuzing ne help?
Old Apr 7, 2003 | 09:07 AM
dfoxengr's Avatar
basically if its only reading a voltage why cant you use it this way?
Old Apr 8, 2003 | 01:35 PM
dfoxengr's Avatar
come on...
Old Apr 8, 2003 | 03:24 PM
dfoxengr's Avatar
i know someone else has an idea about this setup...
Old Apr 8, 2003 | 04:01 PM
msilbernagel's Avatar
I think he is serious, and correct, in pointing you to the oz DIY site.
A short answer to your question of why can't I just read the voltage and translate it myself is that part of what the circuitry (controller) does is provide very stable and accurate reference voltage/current required by the sensor, and in return gives you a simple voltage as output.
In other words, there is no 'voltage' to measure without a controller.
By itself, the 5-wire sensor sinks current in complicated ways. The controller handles the complexity and give you a simple A/F --> voltage output.
If you don't have the time, inclination, or training to get through the OZ material, you don't want to mess with the sensor.
Mark
Old Apr 8, 2003 | 04:04 PM
dfoxengr's Avatar
Default Re: a wideband thought? (msilbernagel)
i can "get through" it just didnt want to...
but im saying if u send the 5wire a good voltage, why cant you really just read the output... 1 volt is perect right...then thats what ur aiming for..?
Old Apr 8, 2003 | 04:17 PM
keebler65's Avatar
simply not possible. 1v: you're still thinking of a narrow band sensor. you're just gonna have to trust us on this one. you NEED a controller. its a lot more complicated than a narrow band sensor.
Old Apr 8, 2003 | 04:22 PM
dfoxengr's Avatar
Default Re: a wideband thought? (keebler65)
1v Lambda is stoich..
also straight off their site:
There are several options for a display for the output of the DIY-WB controller.
The simplest, is a plain DVM (Digital Volt Meter). Use the Vout to AFR chart http://www.diy-wb.com/v_out.htm
[Modified by hybridvteceg, 8:23 PM 4/8/2003]
Old Apr 8, 2003 | 04:24 PM
dfoxengr's Avatar
2.5 volts from the sensor is stoich in accordance..
godluvstegs
Dec 15, 2010 07:08 PM
jarven93
Nov 26, 2009 07:18 AM
B20EF
Feb 22, 2008 04:44 PM
Blaise
Nov 17, 2004 09:14 AM
cannon_man
Jun 30, 2002 09:21 PM
