d16z6 swap, how do i find out what cel it's throwing?
Old Apr 6, 2003 | 06:10 PM
serious's Avatar
Default d16z6 swap, how do i find out what cel it's throwing?
i swapped a d16z6 into my 90 dx using the z6 ecu. i built a conversion harness to adapt my wiring to the ecu. however, my check engine light is on and i don't know how to get the ecu to tell me what's wrong. i know in the 5gen you jumper 2 wires together to get the ecu to walk, but i have no clue where or what those wires are.
Old Apr 6, 2003 | 06:41 PM
Noahk's Avatar
Default Re: d16z6 swap, how do i find out what cel it's throwing? (serious)
It depends how you wired the harness. On some of them you just have to ground a wire. On others you jump the ignition setting thing, which is under the hood for 88-89s and under the passenger side kick panel on 90-91.
Old Apr 7, 2003 | 02:58 AM
serious's Avatar
Default Re: d16z6 swap, how do i find out what cel it's throwing? (Noahk)
well, what pin on a p28 ecu do you ground to make to switch it to service mode?
EF_Tovi
Nov 6, 2010 07:20 AM
Deathwish
Apr 19, 2005 10:21 PM
r30slick
Mar 14, 2002 10:59 AM
ImportHatch
Jan 28, 2002 05:50 PM
ImportHatch
Jan 16, 2002 10:12 AM
