Easiest way to refill trans?
Old Apr 6, 2003 | 11:11 AM
zijiejijeijrkjk's Avatar
Default Easiest way to refill trans?
I remember seeing someone post about refilling from the top of the case. What do you remove to do so? That elect. connection right next to the nipple thing?
tia,
Old Apr 6, 2003 | 11:13 AM
yellow blur's Avatar
Default Re: Easiest way to refill trans? (scott_k)
https://honda-tech.com/zerothread?id=382416
Many pics, so it'll be kinda slow if you're dialup.
Tommy_Gunns's Avatar
I always use the "tranny" fill hole that is located just above the drain hole. But I do fill it from the top with a long hose connected to a funnel.
The reason for using the tranny fill hole is because that's what I use to gauge the correct amount to fill into my tranny. Fill till it leaks out of the fill hole.
Old Apr 6, 2003 | 11:15 AM
Default Re: Easiest way to refill trans? (Tommy_Gunns)
Exactly the post I was searching for, thanks
stella88
20
Aug 20, 2011 02:27 PM
JDMfrontedLS
17
Jun 23, 2006 11:08 AM
girliehonda
Jan 28, 2006 06:52 PM
ludewithanh22
Feb 6, 2005 12:50 PM
sting94112
Feb 22, 2004 01:38 PM
