car jack (the one one to lift up the car)
Old Apr 6, 2003 | 09:28 AM
216.226.142.95:27016's Avatar
Default car jack (the one one to lift up the car)
what are you guys using? how much? how is the clearance when slipping it under the car?
no replies saying im using the car jack that came with the car please.
Old Apr 6, 2003 | 09:35 AM
T3T495GSR's Avatar
Default Re: car jack (216.226.142.95:27016)
mine is kinda low, there is only one way for me to jack it up, i have a big car jack. but i have to use the stock one to fit underneath one of the tow hooks to get the car high enough to get the big jack underneath
then repeat the process to get it back on the ground
Old Apr 6, 2003 | 09:43 AM
ITR 01-0422's Avatar
Default Re: car jack (T3T495GSR)
yeah i have to do the same thing with my bro's LS and my R. my pops just bought some car ramps though, we haven't used them yet so i'm not sure the cars are gonna clear the ramps but we'll soon find out.
Old Apr 6, 2003 | 09:46 AM
VTECorona's Avatar
Old Apr 6, 2003 | 12:51 PM
TrueZen's Avatar
3-Ton High Lift SUV Jack from Sears, I'm a little lower than stock and it just barely fits under the front, but lifting from the tow hook in rear is no problem. Last I saw it was $49.99.
Old Apr 6, 2003 | 04:53 PM
eg_nezay's Avatar
Default Re: car jack (97RedTegGSR)
u guys need to get some blocks( 2x2 ) to make the big jack fit.
EDIT- I have a 3 ton jack btw.
[Modified by eg_nezay, 1:54 AM 4/7/2003]
Old Apr 6, 2003 | 05:31 PM
Thrillhouse's Avatar
Default Re: car jack (eg_nezay)
2.5 ton jack from harbor frieght i think 40 bux. Negative clearance i need blocks.
Old Apr 6, 2003 | 09:00 PM
T3T495GSR's Avatar
Default Re: car jack (Thrillhouse)
EG NEZAY, thats a badass avatar
Old Apr 6, 2003 | 11:33 PM
tC_Dragon's Avatar
i use my stock scissor jack to lift the car a little bit from the side jacking points.. then use the front or rear jacking points with the regular floor jack to lift the rest of the way.. my car is jus a lil too low to have my floor jack clear the bumper n slide in.. so dats wat i have to do.. but its not hard at all.
Old Apr 6, 2003 | 11:49 PM
kev301's Avatar
Default Re: car jack (pdcdragon)
I'm using a 3 ton jack also but for the front, I had a buddy make a small ramp with 2x4 where I can drive up on the ramp. Then use the jack for the front, this would be the easiest way for the front but the rear I use the took hook.
Old Apr 6, 2003 | 11:50 PM
97teg415's Avatar
Ive got a 3 1/2 ton floor jack but lost the pole for it. Anyone know where to buy the pole itself without having to buy the whole jack?
Old Apr 6, 2003 | 11:59 PM
tC_Dragon's Avatar
Default Re: car jack (97teg415)
use a metal broom stick.. dats wat i used before on an old jack i borrowed from a friend.. ghetto but it werks. As for the tightening and loosing of the valve.. jus use a screwdriver.
Old Apr 7, 2003 | 04:48 AM
HKJ's Avatar
HKJ
btw, also using a 3ton jack and 4 3ton car stands.
[Modified by HKJ, 1:49 PM 4/7/2003]
1990hf
May 7, 2005 07:58 AM
92civicsi
11
Jul 21, 2003 02:59 PM
Stock R
May 11, 2003 11:54 AM
-CP-
30
Oct 3, 2002 01:30 PM
