starting problems
Old Apr 6, 2003 | 12:05 AM
Rob!'s Avatar
Default starting problems
a friend of mine has a 92 cx with a 96 gsr swap. we were drivin around and about a mile from where we were goin the check engine light pops on. we we kept drivin till we got there. its throwin a code 41. we were going to my friends to check the compression so we check the compression and its all good so we plug the plugs back up and the wires and go to start the car again and t cranks and cranks but it wont start. wires are on correctly checked fuses, grounds. dont know what it can be. any one have any idea on how to help my boy out? and what is code 41 and what does it mean?
Old Apr 6, 2003 | 07:59 AM
Ricey McRicerton's Avatar
Default Re: starting problems (RaceFacer)
Sounds like a spark problem...start at the coil and work your way out to the plugs!
Old Apr 6, 2003 | 08:06 AM
Chiovnidca's Avatar
Code 41 is a problem with the o2 heater circuit. It's not likely to cause a starting problem. When you did the compression test, did you disable the ignition system? I've seen a few coils get fried.
Old Apr 6, 2003 | 01:13 PM
real9999's Avatar
Default Re: starting problems (TurboD16Chiovnidca)
No Start Diagnostics
Crank
Spark
Fuel
Failed coil or igniter are the most common. Main fuel relay should be suspect too if the weather is really hot.
Tom
Old Apr 6, 2003 | 05:21 PM
Rob!'s Avatar
Default Re: starting problems (real9999)
there is no spark. and it was on a damp cold night.
Old Apr 6, 2003 | 05:22 PM
Rob!'s Avatar
it gets fuel
Old Apr 6, 2003 | 05:40 PM
Chiovnidca's Avatar
there is no spark.
Did you check the coil?
Old Apr 6, 2003 | 05:42 PM
speedaccordinly24's Avatar
how do u know it gets fuel?
Old Apr 7, 2003 | 04:50 AM
Rob!'s Avatar
Default Re: starting problems (speedaccordinly24)
i did not check the coil yet.
i know it gets fuel because i hear the fuel pump turn on and i cracked the fuel rail and fuel squirted out therefore it is getting fuel. like i said i know the problem is no spark. anyone else?
[Modified by RaceFacer, 1:50 PM 4/7/2003]
Old Apr 8, 2003 | 06:39 PM
sailor's Avatar
Default Re: starting problems (b16hf)
check ur coil, and icm.
flyinkman
May 1, 2013 07:09 PM
rice a roni
Dec 16, 2006 09:28 AM
willyboyK20
Jul 2, 2003 08:10 PM
Rob!
Apr 7, 2003 08:22 AM
reVVin
Mar 31, 2002 07:03 PM
