gsr dash cluster into 89 hatch
Old Apr 5, 2003 | 07:27 PM
OutLuDeD's Avatar
Default gsr dash cluster into 89 hatch
hey, i know ive seen the swap done before. i want to put a gsr dash cluster into my 89 dx hatch. how hard is it to do? is it a simple clip in or do i have to do some wiring?
Old Apr 5, 2003 | 07:28 PM
SteveeeO's Avatar
Default Re: gsr dash cluster into 89 hatch (OutLuDeD)
a lot of wiring, I think the conversion is around here (if it's not archived)
Old Apr 5, 2003 | 07:39 PM
1.8T_EG's Avatar
Default Re: gsr dash cluster into 89 hatch (SteveeeO)
... i'd like to know too... bump...
Old Apr 5, 2003 | 09:13 PM
Riceburner247's Avatar
Default Re: gsr dash cluster into 89 hatch (1.8T_EG)
interested in GSR cluster into a 91 as well.......search is down
Old Apr 6, 2003 | 12:14 AM
uneek4dr's Avatar
Default Re: gsr dash cluster into 89 hatch (riceburner247)
simple wiring, but ALOT of it. as far as the ESS i have NO clue on how to do that. I just used a 90-93 cluster because it had a cable speedo. The wiring is basic matching of wires and splicing together....thats as much help as i can be
Old Apr 6, 2003 | 04:13 AM
^Sammy]!.'s Avatar
From: 9/11/01 WTC Never Forget, United States Of America
here you go Outluded: (You would need an electronic VSS from a 92+ civic dseries and a 94+ GSR cluster harness also get a cluster cover from a 90-91 hatch the gsr cluster will not fit into the 89 cluster cover)
any question email me: siderazeref9@aol.com
be easy and take your time
But if you dont wanna go through all this trouble get a 90-93 integra cluster because of the cable vss instead of electronic vss you will still thought need a 90-93 cluster harness and rewire i dont have that diagram but i know someone here has it.
Here's a diagram pin side integra cluster 96 I think. However I know between 94-97, and 98+ the fuel gauge and other warning lights are in different locations. So I think if your cluster is 98+, switch b1 and b3 around on this diagram. I had to adjust mine when i went from 94 jdm cluster to 98 type r cluster. I think if your looking at the back of the cluster you can start left to right b1, b2
Integra harness
D1 - Hazards
D2 - Maintenance
D3 - Blank
D4 - Switched power to cluster
D5 - Cruise Control
D6 - Ground
D7 - ECT
D8 - Blank
D9 - Alternator volts
D10 - Blank
D11 - Oil Pressure
D12 - Malfunction indicator
D13 - Tach signal
B1 - Fuel Gauge
B2 - Door Open
B3 - Blank
B4 - Fuel low level sensor
B5 - Blank
B6 - VSS
B7 - Hatch Indicator
B8 - Seat Belt Reminder
B9 - Dimmer
B10 - Gauge lights
B11 - Ignition Black/Yellow
B12 - Blank
B13 - Left turn signal
B14 - Right turn signal
B15 - High Beam Indicator
B16 - Parking Brake light
Civic harness (wire color codes)
C1 Hazards
C2 empty
C3 empty
C4 Yellow Switched Power
C5 empty
C6 Black Ground
C7 empty
c8 Yellow/green Brightness
C9 White/Blue Battery
C10 empty
C11 Yellow/Red Oil pressure
C12 Green/Orange Check engine
C13 Blue Tachometer
B1 Red/Blue Fuel gauge
B2 empty
B3 empty
B4 Green/Yellow Low fuel light
B5 empty
B6 Orange Speedometer
B7 Blue/Black Trunk/hatch open
B8 empty
B9 Red Brightness
B10 Red/Black Gauge lights
B11 Black/Yellow VSS
B12 empty
B13 Green/Red-1 Silver Stripe Left turn signal
B14 Green/Yellow-1 Silver Stripe Right turn signal
B15 Red/Green n/a
B16 Green/Red Emergency brake
and to hook up electronic VSS...
blue/white to orange
black/yellow to yellow
black is the ground.
[Modified by MR.RED'89, 5:16 AM 4/6/2003]
[Modified by MR.RED'89, 5:23 AM 4/6/2003]
Old Apr 6, 2003 | 07:38 AM
dingusjt's Avatar
After hours of wiring i found out how simple it is.....I'll have to look at my cluster and figure out what wires were switched but pretty much everything matches color to color except 2 wires...
also electronic VSS is easy too as long as long as you have the plug, again just drop it into your tranny and then you are running 3 wires, 1 is a black ground, on is power which taps into your Gauge cluster power wire, and 1 is a signal wire that hooks up to Orange i believe...
really really simple the hardest part is fitting it in their properly i had to take out stock mounts and cut ears off the sides of the GSR cluster but it looks real nice..
DO NOT USE THE DIRECTIONS FOUND AT...http://www.angelfire.com/dc/oregonimport/gsr1.html
thats what turned an 30 minute job into about 3 hours of hasseling.
Old Apr 6, 2003 | 08:27 AM
Stunna BEN's Avatar
Don't call it a comeback
Default Re: gsr dash cluster into 89 hatch (dingusjt)
Thanx for the diagram. Anyone tell me how well the 90-93 cluster fits???
Old Apr 6, 2003 | 08:29 AM
dingusjt's Avatar
Default Re: gsr dash cluster into 89 hatch (Stunna BEN)
no i said don't use those instructions they are just confusing and incorrect and the 90-93 cluster should fit exactly the same as the 94+ however you wont need to convert to electronic VSS you can just use your cable driven VSS. for the speedo
Old Apr 6, 2003 | 02:26 PM
uneek4dr's Avatar
well the 90-93 cluster didnt fit very well into my sedan dash. if it does in the hatch dash is a totally different story. Was way easy to wire and everything but fitment is a BITCH lol
Old Apr 6, 2003 | 02:38 PM
dingusjt's Avatar
Default Re: gsr dash cluster into 89 hatch (uneek4dr)
i found out just like you did 94+ cluster didn't fit too well into my sedan...looks really nice though, amber glow and all its just that at the sides and bottom fuel/temp gets cut off a bit and ebrake/high beam lights do to...
Old Apr 6, 2003 | 02:47 PM
YumVTEC's Avatar
i'm interested in seeing pics of this setup. i have a 92 gs-r cluster I want to put into my wife's 90 EF.
Old Apr 6, 2003 | 05:26 PM
ghettocrxsi's Avatar
Default Re: gsr dash cluster into 89 hatch (YumVTEC)
I am the one who wrote the instructions on http://www.angelfire.com/dc/oregonimport/gsr.html how ******* hard is it? Its only took me 30 mins to wire it up using that same wiring diagram. vss is easy it goes ground black. signal white/blue on most and power blue/yellow.. Also those directions I made are only for 90-91
Old Apr 6, 2003 | 07:45 PM
smokey2.0's Avatar
can anyone post a picture of a 94+ gsr, in their 88-89 crx/hatch!
Old Apr 6, 2003 | 10:50 PM
Default Re: gsr dash cluster into 89 hatch (smokey2.0)
in an 88-89 you have to use a 90-91 cluster cover here are pics of mine in a 90-91
Old Apr 6, 2003 | 10:59 PM
bfrank81's Avatar
Default Re: gsr dash cluster into 89 hatch (ghettocrxsi)
I love that!!!!!
to you!!!
Old Apr 7, 2003 | 10:06 AM
YumVTEC's Avatar
Default Re: gsr dash cluster into 89 hatch (bfrank81)
I love that!!!!!
to you!!!
yeah, it does look good. wow. i still want to see a DA cluster in an EF though.
Old Apr 7, 2003 | 10:22 AM
uneek4dr's Avatar
http://www.4thgenerationcivic.com/ho...ket-Custom.htm
go there scroll down its installed but not in the dash and its is my complete write up on how to swap in the 90-93 cluster into a 88-89 civic
Old Apr 7, 2003 | 06:52 PM
smokey2.0's Avatar
it looks great in a 90-91 car, but i wanna see how the cover fits in the 88-89 car. i hear that there's a gap left, when using the 90-91 cover in a 88-89 car! tha's why i would like to see it in a 88-89 car!
Old Apr 7, 2003 | 06:56 PM
Stunna BEN's Avatar
I love that!!!!!
to you!!!
Agreed. A finished product pic just to see how well fitment was.
Old Apr 7, 2003 | 07:13 PM
^Sammy]!.'s Avatar
well here is my 97 gsr cluster in 89 hatch with a 90-91 hatch cluster cover
do not use the cluster cover from a crx u will have a gap if u use that one.
cluster cover from hatch for hatch
cluster cover from crx for crx
and now here is the pic:
the defroster works cause when i got the 90 hatch cluster cover i also got the harness with the switches i have the harness for the hazards switch im gonna wire it so that i can use the switch on the cover instead of the one on the steering wheel column.
BTW: I will be repainting the vents black...........
[Modified by MR.RED'89, 8:21 PM 4/7/2003]
Old Apr 7, 2003 | 07:20 PM
YumVTEC's Avatar
that was a great link. i wish someone would just post a pic of the finished product in a civic dash though. i'll be the first one to post it if no one else does. give me about 2 months though.
Old Apr 7, 2003 | 09:44 PM
a good cluster to put in the ciivc is the 00 si cluster.. since the civic has that more square opening
Old Apr 8, 2003 | 04:31 PM
88civicHB703's Avatar
Default Re: gsr dash cluster into 89 hatch (MR.RED'89)
man some ppl will just go the distance wow musta took amazin patient i could do that for the world... awesome guauge fitment.
Old Apr 8, 2003 | 06:11 PM
illi Adik's Avatar
S2K seats and a GSR cluster, so nice.
