A/F gauge installation... Where should i tap it?
Okay here is my p6 ECU and I'm trying to figure it out where are the o2 sensor wire, power, and ground wire?
A/F gauge wire
Red=power
Black=ground
Purple=O2
A/F gauge wire
Red=power
Black=ground
Purple=O2
Dude just run the purple wire to your main o2 sensorin the exh. manifold. its only 1 wire. much easier, solder your conenctions otherwise your car will run like crap.
Blaze
Blaze
Blaze
Blaze
it will be rich reading until you drive around and warm up the car.. unless you have already done that and it still reads rich.. maybe it's messed up
which air/fuel gauge did you get ? i got this one "im not sure of the brand" but its all black and it only reads in bars .. but anyways its garbage .. some times it works sometimes isnt doesnt and its never accurate.
Guest
Posts: n/a
some times it works, some times is doesnt = shitty o2 sensor.
Guest
Posts: n/a
BlazeI did run the purple to the o2 sensor wire(white) and for some reason it's not reading my air fuel ratio. I got the power and the ground is in good connection, and still on the solid green rich reading. It should be moving around or something.
go drive it .. it'll work
is on me.
Thanks for the inputs guys.
danno33
17
Aug 9, 2007 07:41 PM
