removing valve cover??
Old Apr 5, 2003 | 04:32 PM
GroundZer0 336's Avatar
Default removing valve cover??
how do i remove my valve cover. d16a6, for painting. and how do i put it back on, ive never tried before
Old Apr 5, 2003 | 04:42 PM
nick.na's Avatar
Default Re: removing valve cover?? (orgasmobile)
haha (sorry) pretty simple actually...theres these chrome looking little nuts that have round tops...should be about 6 of them maybe on that motor? I dunno, but turn them (righty tighty lefty loosy) then the valve cover pops right off...do not loose the little black rubber grommets that are in the holes though, you'll see what I mean
edit...to put it back on...set it in place...makeing sure the rubber seal (gasket) is in place as well, then tighten down the buts again
[Modified by amber-bling, 1:43 AM 4/6/2003]
Old Apr 5, 2003 | 04:49 PM
Default Re: removing valve cover?? (amber-bling)
nah reallly???? im not dumb. my bad tho i shoulda just asked about the plug wires. i dunno how to get them out. i dont wanna mess up anthing. my guess is just pull. but i dont know. hhaa. im stupid about engine stuff. thats why everything is still stock and i have the slowest si around
Old Apr 5, 2003 | 06:29 PM
drjondurst's Avatar
lol damn man, be a lilttle more brave. Yes just pull them out.
Old Apr 5, 2003 | 06:49 PM
Donkey85's Avatar
Default Re: removing valve cover?? (drjondurst)
just be sure not to tighten them too tight when putting them on. just barely tighten then because they will snap right off if you start to wrench them too tight
Old Apr 6, 2003 | 01:14 PM
photonjedi808's Avatar
this is just sad
you should just pay somebody to take off your valve cover before you break something
Old Apr 6, 2003 | 01:15 PM
rated_r's Avatar
Default Re: removing valve cover?? (photonjedi808)
put a ne gasket on it after u take it off
Old Apr 7, 2003 | 04:48 PM
90da's Avatar
Default Re: removing valve cover?? (rated_r)
While you're in there you may aswell get new spark plug seals...for the 4-5 bux it is worth it.
Old Apr 7, 2003 | 06:51 PM
Hcivic88's Avatar
Default Re: removing valve cover?? (90ef)
dont forget to unbolt the ground too from the front right. and also, the tube coming from the intake at the back left that just clamps on. after that, theres just the 4 bolts for the valve cover, pull the plug wires out and it should come right off.
Old Apr 7, 2003 | 08:05 PM
blah13's Avatar
Default Re: removing valve cover?? (Hcivic88)
If it doesnt come off easily take a <U>rubber</U> hammer and tap it on the sides.
Old Apr 13, 2003 | 04:28 AM
Neptune's Avatar
Hey I just did it last night, painted mine red with black lettering, looks great and it was really easy. Im me someitme if you need any help, I live in Greensboro too.
Old Apr 13, 2003 | 08:57 AM
Default Re: removing valve cover?? (Neptune)
i dunno how to i.m. on this thing. you live in gboro thats cool . i hate it here, youve prolly seen my car around somewhere.
Old Apr 22, 2003 | 01:07 PM
ITR00-1200
Guest
Posts: n/a
Is it neccessary to get a new gasket when putting in another valve cover? how much they run?
Old Apr 22, 2003 | 03:30 PM
Hcivic88's Avatar
Default Re: removing valve cover?? (ITR00-1200)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR00-1200 &raquo;</TD></TR><TR><TD CLASS="quote">Is it neccessary to get a new gasket when putting in another valve cover? how much they run?
im not sure if its necessary to replace it, but i'd recommend it.
i'd say they're around $15 - $30 US.
Old Apr 22, 2003 | 04:39 PM
keebler65's Avatar
it all depends on how worn your old one is. i got mine (for a B16) for $12.99 at autozone, so i figured it was worth it. the worst thing that will happen is a little oil will leak out over time. no biggie, but why not prevent it if possible?
Old Apr 22, 2003 | 08:05 PM
RicedREX's Avatar
Default Re: removing valve cover?? (keebler65)
if you are just figuring out how to remove your plug wires I wouldnt mess with the gasket, sometimes putting in new ones cause leaks. They cost $12.99 BTW.
b0yg0tskills
Honda Civic (2001 - 2005)
Nov 11, 2007 07:08 PM
knucklehead11
Jul 31, 2004 05:13 AM
Dirk McGirk
Oct 5, 2003 05:56 PM
kreamy
Oct 2, 2003 06:43 AM
ActiveAero
Jun 7, 2003 02:31 PM
