'97 and '00 ITR have different cams?
Old Jun 21, 2001 | 12:47 PM
NA1's Avatar
NA1
New User
Default '97 and '00 ITR have different cams?
I've heard '00 ITR using CTR cam that's why they're a bit faster than '97 ITR. True?
Old Jun 21, 2001 | 12:57 PM
Speedy's Avatar
New User
Default Re: '97 and '00 ITR have different cams? (NA1)
I'm not sure about that but...There is another old saying that when planting peas and beans, the rows should always run north and south. This makes sense since the sun moves from east to west and gives the plants maximum sunshine. Neat!
Also... In regards to the idea that you can "let a dog lick a wound because a dog's saliva is antiseptic and will kill germs." This is totally untrue. Dog mouths are infested with the germs of everything they put into them. If you or another animal receives a dog bite, it is like injecting yourself with a large dose of germs, which is why infection is almost inevitable.
Don't let your dog excessively lick his own wounds, either. Veterinarians often give wounded dogs Elizabethan collars or buckets for their heads to prevent the dog from keeping his wound open or ripping out stitches. On the other hand, a mother licking her pup's wound can debride the area allowing faster healing, which is what probably brought about this saying.
I hope that helps!
Old Jun 21, 2001 | 01:03 PM
tegtyper's Avatar
Default Re: '97 and '00 ITR have different cams? (Speedy)
Whatcha growin' Speedy?
Old Jun 21, 2001 | 01:04 PM
yoshi234's Avatar
I shoot brides
it also helps to pee on jellyfish stings.
Word from a very credible source says the 00&01 cams *are* diff from 97&98 cams.
yoshi - who doesn't want to get stung by a jellyfish
Old Jun 21, 2001 | 01:05 PM
FBP_1171's Avatar
They are different:
Part number's for those interested
00-01 ITR intake cam 14111-P73-J01
97-98 ITR intake cam 14111-P73-J00
Some of you may have heard/read rumors the 00 ITR cam is the same as
CTR cam. "They are very similiar to but not as aggressive as the CTR
cam. They are "slightly" more aggressive than the 97-98 ITR cam
though." This from my source at Honda.
This came from a friend who is a Honda mechanic working at a local dealership.
Old Jun 21, 2001 | 01:09 PM
Big Phat R's Avatar
Default Re: '97 and '00 ITR have different cams? (FBP_1171)
King Motorsports says the same thing.
Old Jun 21, 2001 | 01:15 PM
XR4racer's Avatar
Default Re: '97 and '00 ITR have different cams? (yoshi234)
It also helps to pee on Stingray wounds, but for a totally different reason.
Robert - Who has already been wounded by a stingray.. The most painful thing I have ever felt. I think I would rather give birth.
Old Jun 21, 2001 | 01:24 PM
mR652's Avatar
New User
Default Nice Link!
It's true, the newer model ITRs do have a more aggresive cam than the 98 spec models. Here is a nice link that will help explain the difference better: http://tiiite.b16a.com/VtecCams.htm
Old Jun 21, 2001 | 01:27 PM
Speedy's Avatar
New User
ok, dino-d00d, but did you know that...
The wild foxglove is a fairy plant in folk-tradition, and has several other names such as Fairy Weed, Dead Men's Bellows, Bloody Man's Fingers, and Witches' Thimble. The Irish believe that foxgloves in the house are unlucky. It should never be taken aboard a ship. To pick the Foxglove is to offend the fairies that live within the flowers and will bring bad luck, even death, to the picker and his family.
The truth of this saying probably lies in the fact it contains a chemical known as digitalis. Used in proper dosages it is often used in modern medicine to treat heart disease, since it slows the rhythm of the heart. However, taken in larger doses, the heart will slow completely until death results.
You have probably heard the saying, "You can make ice faster by starting with warm water." Is this statement truth or fact? Actually, it is true because hot water is steaming, and the process of evaporation (the steam rising) is a cooling process, thus actually causing hot water to freeze faster than cold.
The phrase "getting out on the wrong side of the bed" usually refers to someone having a bad day, or feeling grumpy or crotchety. This goes back to the superstition that, by going to bed on one side at night and getting up out of the other side in the morning, one formed a protective magic circle. Not to do so was bad luck.
The lucky horseshoe is a throwback to a time when it was thought that witches rode on broomsticks because they were afraid of horses. Nailing a horseshoe over your door kept witches from entering.
Speaking of witches, that's an old wives tale that isn't true. Witches weren't really afraid of horses. The reason they ride broomsticks is so that they can fly. Almost everyone knows that! The broomstick (with the bristles forward, please) is a symbolic horse, and used to be commonly used as such by children, when it was called a hobby horse. Why witches were thought to use brooms rather than real horses probably has to do with the poverty most old women endured. The women who were thought to be witches were generally too poor to own a real horse, but almost anybody can own a broom.
The reasoning behind the phrase "Breaking a mirror brings seven years of bad luck" originates in a period of time when the cost of a mirror was so much, it would take approximately seven years to save enough money to replace it.
speedy, who's full of helpful hints today
Old Jun 21, 2001 | 01:54 PM
MOD5CSi's Avatar
New User
or is that speedy, who has way to much time on his hands?
doug...who thanks speedy for the helpful hints!
Old Jun 21, 2001 | 02:26 PM
HapaHaole's Avatar
Default Re: '97 and '00 ITR have different cams? (MOD5CSi)
dood if you take a dump on a bee sting...NM
im gonna run 00ITR cams on my built motor anyway. im sure ill make plenty of usable torque anyway.
yeah...................LS
Old Jun 21, 2001 | 02:29 PM
Jimmy L's Avatar
Default Re: '97 and '00 ITR have different cams? (yeah LS)
Speedy
You should put all of that together in a book, like Poor Speedy's Almanac.
Old Jun 21, 2001 | 02:42 PM
yoshi234's Avatar
I shoot brides
39 speedy:
If you tell a dream before breakfast, it will come true.
Knocking on wood (aka "touches w00d" in aussie land) will prevent something bad from happening.
If a cricket gets in your house, it's the sign of a death.
A brown wooly worm means a mild winter, a black wooly worm means a cold winter.
Coming in one door and leaving by another door will bring the person you are visiting more company.
If your nose itches, somebody is coming to visit.
And if your butt itches, j00 spent t00 much money for that mod!
yoshi - who's butt doesn't itch yet
Old Jun 21, 2001 | 04:47 PM
ITRbroham's Avatar
shit post warrior
Jus wonderin'
If the 00' and 01' models have slightly more aggresive cams than the 97 and 98 models, then why does it make the same power! HMMMMMM.....seen dyno sheets from both and they look almost identical (i.e midrange and top end)
Does anyone know?
Old Jun 21, 2001 | 04:55 PM
R748's Avatar
Default Re: '97 and '00 ITR have different cams? (IntegraTypebRo)
Jus wonderin'
Does anyone know?
Exactly, this has been my observation as well. Unfortunately, people pick someone with a good engine and hold it up as proof that the 00+ cars are faster. However, there were strong engines even in the 97/98/99 cars.
The carms are probably different, who knows what Honda did with the software in the car. Let's see how long it takes someone to say "But SCC got much faster times with 00 cars".
Old Jun 21, 2001 | 06:55 PM
SamB's Avatar
New User
Default Re: '97 and '00 ITR have different cams? (R748)
Y - I presume you are referring to my previous post. It is "touches w00d" in Kiwi land, New Zealand is NOT part of Australia. hehehehe j/k
Speedy - ROFL
Sam - Who is not an Aussie (Thank you God )
Old Jun 21, 2001 | 06:58 PM
citanest's Avatar
New User
none sense!!!!
stop the BS
Evolution-93-Ex
Nov 21, 2008 10:36 AM
oMek
Oct 11, 2003 06:58 PM
markpaco
Jan 24, 2003 08:08 PM
HX_Guy
Jan 17, 2002 05:44 PM
