ls motor into 2000 ex
well i can get a 93 ls motor, tranny, ecu, wiring harness for free, im gonna need to get a flwywheel and clutch assembly but what else am i gonna need to get this motor into my 2000 ex coupe.
axles?
mounts?
axles?
mounts?
also what flywheel and clutch do i get and where do i get it, keep in mind cost is and issue, i dont suppose a d series clutch would do me any good would it, and can i use stock mounts
I believe you would need to get mounts from a 99-00 Si
Fairly easy
Axles, you would need 94+ Integra axles, also you would need a 94+ integra tranny, unless you wanna go through the hassle of getting a hydro-cable converter.
I wouldn't recommend the swap for a few reasons. The gains you will see are minimal, only thing you are really gaining is some torque. The motor is OBDI and has a cable tranny. You would need a hydro tranny or hydro to cable conversion, new mounts and an OBDI to OBD2.5 converter. It's truly not worth the $ and hassle to put the motor in there. You said the motor was free but it's not really free when you are trading swaps with one another. Save your $ and get a newer complete B18B, B18C or B16A.
im just trying to gather all the info before i decide if its worth it, but im really confused. could some one tell me what specific mounts ill need and where to get the axles, tranny converter, and wiring converter? thanks in advance
axles from classifieds, junk yard or online shop like hmotorsonline.com...prolly around $200 for a used pair I think...tranny converter I have to find the link but I believe that's also around $200...and for the wiring converter I believe there are a few guys on this board that make them, do a search and I believe they are like $150+.
thanks for your help, now im seeing why people say its not worth it. for that price i could get a btm, and a boost controller and hit near 300hp tuned.
