zc help
help just swaped zc into 91 hf motor came with all wiring used that did not start changed th stock harness still nothing it cranks over but wont fire i changed everything cap,rotor,plugs,wires,etc please help
also it backfires when i turn the key off if that helps
i had a d16z6 in it with a zdyne b16a 1 wire conv. i just blew the motor and got a zc
i've checked everything but i also had two wires that could not be connected by the resistor box thats why i changed to the hf harness
With this swap it is best to use the HF harness. The EGR plug will not be used if I remember correctly. As for the cam sensor go here: http://www.geocities.com/civiczc/zcwire.html I'm a little confused...why not just use a PM7?
i first tried the zc harness that came with my motor i tried to start it and got a code 15 ing output so i switched to the hf harness and spliced in the cam angle sensor it still won't start but i don't get any codes with the hf harness, and i'm really confused about what the real firing order is.
whiter14
Aug 4, 2010 01:07 PM
h22_crx
Mar 10, 2006 04:39 PM
pyro_freak8
Mar 25, 2004 01:30 PM
