fuel pressure queston for b16a2
Old Apr 5, 2003 | 12:24 PM
queez's Avatar
Default fuel pressure queston for b16a2
sorry search yeilds nothing..
just installed fuel pressure gauge and with stock injectors and pump. it reads 35-36 psi, running. is this right??? i just installed the fpr from B&M and gauge, and kept it at 35-36psi. but want to know if it should be higher...
Old Apr 5, 2003 | 05:37 PM
queez's Avatar
Default Re: fuel pressure queston for b16a2 (queez)
bump.....
Old Apr 5, 2003 | 08:01 PM
dfoxengr's Avatar
did you disconnect the vacuum from the back of the FPR when checking?
Old Apr 6, 2003 | 10:33 AM
queez's Avatar
Default Re: fuel pressure queston for b16a2 (hybridvteceg)
actually no i didnt.. llllllllllllllllll
Old Apr 7, 2003 | 11:58 AM
queez's Avatar
bump... i disconnected the vacum line, and then adjusted it to 36 psi.. so now is this right???
Old Apr 7, 2003 | 04:26 PM
dfoxengr's Avatar
sounds good...GSRs are stock 45 and i think LS is around 38
hondapowerb16a2
Mar 20, 2010 01:15 AM
Rikaro
11
Sep 28, 2008 08:52 PM
TegLove
Mar 29, 2004 05:06 PM
Joon525
Sep 8, 2003 11:51 AM
Lei Siew Long
Jul 1, 2001 03:11 PM
