Will the Snap-on valve seal remover tool, work for hondas?
Old Apr 5, 2003 | 11:30 AM
sporkcrx's Avatar
Default Will the Snap-on valve seal remover tool, work for hondas?
I checked with the truck at my work, and he said they only sell one tool for valve seal removing...will this fit the honda valve seals?
Old Apr 7, 2003 | 08:20 PM
sporkcrx's Avatar
Default Re: Will the Snap-on valve seal remover tool, work for hondas? (PIMPASSBEOTCH)
emailed you, about the valve spring compressor...but the tool I'm asking questions about is the valve seal remover. anyone?
Old Apr 7, 2003 | 08:48 PM
the DR.'s Avatar
Default Re: Will the Snap-on valve seal remover tool, work for hondas? (sporkcrx)
if you're talking about the thing that looks kinda like pliers, then it should fit
Old Apr 7, 2003 | 09:18 PM
sparkz's Avatar
and pair of regular needle nosed pliers and some effort is all thats needed to remove valve stem seals
Old Apr 8, 2003 | 06:10 AM
sporkcrx's Avatar
Default Re: Will the Snap-on valve seal remover tool, work for hondas? (sparkz)
sounds even better!
Old Apr 8, 2003 | 07:32 AM
94CivicSi's Avatar
yah, needle nose worked for me. Just be carefull not squeeze the seal too much and deform it. If you "oval" it a bit, it will be signifigantly harder to pull it off. Just enough pressure to grip it, pull straight up.
Old Apr 8, 2003 | 07:33 PM
sparkz's Avatar
Default Re: Will the Snap-on valve seal remover tool, work for hondas? (94CivicSi)
like he said, squeeze lightly to get a grip, and pull straight up
Old Apr 8, 2003 | 07:59 PM
TurboDANDEE's Avatar
that tool will work from snap-on, we've used it before.
Old Apr 9, 2003 | 06:43 AM
KoRE's Avatar
for the valve spring compressor goto northerntool.com same kit for 40-50 bucks
Old Apr 9, 2003 | 11:31 AM
real9999's Avatar
I had a hellish time trying to get them off with needlenose pliers. I wound up getting them pulled at NAPA for $15. I would go with the tool or have someone else remove them. I just about shot myself in the foot when I found out how much easier it is using the remover tool.
Tom
jasoncrashtech
May 25, 2013 08:10 PM
JScott3d
Jan 16, 2008 04:56 PM
lude98SH
Jul 26, 2007 05:39 AM
vinuneuro
Apr 24, 2007 06:05 AM
1.8EG-T
Dec 14, 2003 02:56 PM
